black OEM headlights for 92 accord
nothing black oem, there are jdm 1 piece headlights, but they are expensive, heres an idea to https://honda-tech.com/zerothread?id=1384294
this sounda interesting o me but i have no idea wat u guys are talking about i ven clicked on the link for the other thread can u guys post up picks?
sorry i dunno what DIY means
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typhoon »</TD></TR><TR><TD CLASS="quote">All of the black housings on those OEMs that you see are DIY.</TD></TR></TABLE>
check out cb7tuner.com, they have write ups on how to do it yourself and if your too scared i heard theres a guy willing to paint them for 40-50 bucks + shipping, they also have a few jdm goodies for the CB's, heres an example:
jdm 1 piece headlights with black housing
jdm crystal OEM stock 1 pieces
black housing usdm 2 piece
hope that helps, and yea jdm 1 pieces are pretty pricey, they can average from 200- 250
search on here or google, they have tonesof DIY write ups, i see them all the time.. Im acually gonna do it to my car once i get a new hood
Modified by Honda_Accord at 12:44 AM 10/27/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-specCb4 »</TD></TR><TR><TD CLASS="quote">wholy **** thats my car lol but for real if u want some blackhousing i can do it for you just shoot me a pm</TD></TR></TABLE>
would it be pointless to do a blackhousing, if part of the inside where its like a clear// shiney thing of the light, is broken off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Accord »</TD></TR><TR><TD CLASS="quote">
would it be pointless to do a blackhousing, if part of the inside where its like a clear// shiney thing of the light, is broken off?</TD></TR></TABLE>
please elaborate im sorry didnt quite understand but if ur taalkin about the dome that sits over the low beam bulb the only problem i forsee is u blinding oncoming drivers
What I did was cook my lights at 250 degrees in the oven for about 8 minutes. Then i CAREFULLY pried apart the lights and used painter's tape to mask off the actual reflective surface in the back of the light and the dome. Then I painted everything else black. Then stick it back in the oven the same way, take it out, put silicone in the groove and stick it back together. Hold for a couple of minutes and you will have custom lights that do not leak.
id really like to get the black housing done for sure, that sounds awesome, then what do you do about the corners? just get black ones?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2290 »</TD></TR><TR><TD CLASS="quote">What I did was cook my lights at 250 degrees in the oven for about 8 minutes. Then i CAREFULLY pried apart the lights and used painter's tape to mask off the actual reflective surface in the back of the light and the dome. Then I painted everything else black. Then stick it back in the oven the same way, take it out, put silicone in the groove and stick it back together. Hold for a couple of minutes and you will have custom lights that do not leak.</TD></TR></TABLE>
What I did on my '95 wagon was used a heat gun to soften the glue itself, but would "even out" the heat to not melt anything. It only took 5 minutes per light to remove the outer lens to get to the reflector part. That way only the glue gets the heat and everything else stays cold and you can handle it. But everything else you did I did too.
Added: Here's how mine turned out........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM MonopolyMan »</TD></TR><TR><TD CLASS="quote">Do you notice any difference in the brightness of your headlights while driving at night?</TD></TR></TABLE>
On mine, no. They have the same effectiveness as they were stock. I'm going to do this mod on my co-worker's 93 Prelude.
No because you aren't painting the light projecting piece of the headlight.
OctaneR34HondaAccord
Dec 26, 2005 10:20 PM
verbol axsassin
Oct 22, 2005 02:33 PM
