can i use obd1 injector with my resistor box on my jdm obd0 b16 swap
Old Sep 26, 2005 | 07:53 PM
racingant's Avatar
Default can i use obd1 injector with my resistor box on my jdm obd0 b16 swap
how will my motor run if i us the obd1 injector or is it better to just get obdo injector for my jdm obd0 b16 swap in my 91 civic si that still obd0 wht is better
Old Sep 26, 2005 | 08:03 PM
90efhb's Avatar
Default Re: can i use obd1 injector with my resistor box on my jdm obd0 b16 swap (racingant)
odb1 injectors wont wokr cause they are high imp. and obd0 ones are low imp.
Old Sep 26, 2005 | 08:25 PM
Mach69's Avatar
Default Re: can i use obd1 injector with my resistor box on my jdm obd0 b16 swap (90efhb)
The obd-1 injectors use high voltage to tell them to fire the fuel. Meaning, if you put a resistor box between the ecu and the injectors, that will cause the voltage to be lowered. So the injectors, theoretically won't fire.
Obd-1 injectors, no resistor box.
Obd-0 injectors, use the resistor box.
You can run either obd series of injectors you want. If you want to use obd-1 injectors, just cut off the resistor box and sauter all 5 wires together where the resistor box was 'cut' off. If you want to use obd-0 injectors, just put them in and keep the resistor box.
Old Sep 27, 2005 | 04:31 AM
racingant's Avatar
Default Re: can i use obd1 injector with my resistor box on my jdm obd0 b16 swap (Mach69)
i have the obd1 injector in on my swap for about 1 month and the is running fine other then at idle it would go up and down i took it to a shop and they told me if i put back the obd0 jnjectors i would fill more power and vtec would kick harder is the true
Old Sep 27, 2005 | 01:49 PM
racingant's Avatar
bump
Old Sep 27, 2005 | 02:29 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant &raquo;</TD></TR><TR><TD CLASS="quote">i have the obd1 injector in on my swap for about 1 month and the is running fine other then at idle it would go up and down i took it to a shop and they told me if i put back the obd0 jnjectors i would fill more power and vtec would kick harder is the true</TD></TR></TABLE>
You are using obd-1 injectors and using the resistor box at the same time? I am surprised that there is enough fuel for the engine and that the injectors are firing.
Old Sep 28, 2005 | 04:43 PM
racingant's Avatar
is i'm using obd1 injector with the resistor box and it fine but if i use the obd0 injector do u think it will run better or the same because i have the obd0 ones
Old Sep 28, 2005 | 05:10 PM
Mach69's Avatar
Try replacing the obd1 injectors with the obd0 ones. It can't hurt doing it. In theory, you should have more power, and I believe you will.
Please, I am not saying you are stupid in any way, make sure there is a resistor box there before using the obd-0 injectors, if the resistor was somehow taken out with the obd-0 injectors there, it will fry them.
Randysi
Apr 4, 2012 10:17 AM
surkitroller
Dec 29, 2009 12:58 PM
D.Dappa
Jan 18, 2005 06:56 AM
mr. Grind
Aug 15, 2004 12:13 PM
kur0ryu
Apr 26, 2004 05:05 PM
