D15B Series Motor Swap into a 1995 Honda Civic Ex
Old Sep 26, 2005 | 07:53 PM
xfletcherxx's Avatar
Default D15B Series Motor Swap into a 1995 Honda Civic Ex
So here's my plan of action: I'm about to pull the broken down D16Z6 motor out of my car and throw a cheap D15B JDM motor into it. There's a few things I need to know though.
Am I going to have to change out the transmission, or will it work out with the current one I have in it?
Are the motor mounts the same, or am I going to have to get new motor mounts also?
Will the JDM motor pass emissions, or am I going to have to go to the local barrio?
Anyway, if someone can answer these questions for me, it'll help me out a great deal.
Thanks,
Fletch.
R.I.P D16Z6
Old Sep 26, 2005 | 07:59 PM
Scrapin4DR's Avatar
Default Re: D15B Series Motor Swap into a 1995 Honda Civic Ex (xfletcherxx)
stock transmission and motor mounts will work and since it's an ex , i don't think there will be any wiring issues should be plug and play, as fo emissions i think it'll pass but i'm not sure , somebody confirm this
Old Sep 26, 2005 | 08:02 PM
ABK's Avatar
ABK
Default Re: D15B Series Motor Swap into a 1995 Honda Civic Ex (Scrapin4DR)
you might need to use your IM if you got a purge solenoid, otherwise it will throw a code. Need to use your 4 wire o2 (jdm d15b uses 1 wire). I think mounts will match up, maybe except driveside, but then again you can take the braket of the z6 block and put it on the jdm d15b.
Everything else is the same.
Old Sep 26, 2005 | 08:10 PM
IT'S ME DAVID's Avatar
NooB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scrapin4DR &raquo;</TD></TR><TR><TD CLASS="quote">stock transmission and motor mounts will work and since it's an ex , i don't think there will be any wiring issues should be plug and play, as fo emissions i think it'll pass but i'm not sure , somebody confirm this </TD></TR></TABLE>
Old Sep 26, 2005 | 08:40 PM
Default Re: D15B Series Motor Swap into a 1995 Honda Civic Ex (K SERIES)
Thanks a lot.
v8destroyer
Jan 24, 2008 05:37 PM
Blazen_angles
Dec 20, 2007 07:43 PM
dseries.vtech
10
Dec 4, 2004 08:58 AM
