Will RSX injectors work in my sol???
Old Sep 26, 2005 | 05:29 PM
MR_EJ8's Avatar
Default Will RSX injectors work in my sol???
Just as the topic says...i have a 97 sol with a Y8 and my buddy is selling the stock 320's out of his rsx...will they work in my car with no modification or will i have to do some rewiring???
Also, what would you guys pay for stock RSX injectors? i believe they are out of his type r motor, not possitive tho.
Thanks in advance
Old Sep 26, 2005 | 05:31 PM
Stoich EG2's Avatar
Default Re: Will RSX injectors work in my sol??? (sohc_sol)
your stock injectors are fine?
Old Sep 26, 2005 | 05:42 PM
Sliced Beard's Avatar
Default Re: Will RSX injectors work in my sol??? (ADVAN EG2)
why do you want larger injectors......do you have a turbo with like 3psi......do you plan on tuning it.....what is your reasoning.
that much fuel will make your 1.6l run like **** and probably mess up sensors and give you shitty gas mileage
Old Sep 26, 2005 | 05:46 PM
MR_EJ8's Avatar
Default Re: Will RSX injectors work in my sol??? (DirtySol)
i figured i would get some of these questions...im planning on boosting again, and yes it will only be around 5 psi untill i get a built block. I just figured this would be cheaper then getting some rc 310's that i would just be using for a short time.
Old Sep 26, 2005 | 06:32 PM
MR_EJ8's Avatar
Anyone want to actually answer my question with an answer instead of another question??? i would really appreciate it!
Old Sep 26, 2005 | 07:05 PM
you might have to wire in the OBD2b2 injector pigtails but it is not very hard.....just be sure to solder the joints.
Old Sep 26, 2005 | 07:08 PM
MR_EJ8's Avatar
thanks
Old Sep 26, 2005 | 07:10 PM
Laserjock's Avatar
no, the IM manifold end will fit but the fuel rail end of the injectors won't. unless you get someone to machine it down but ...ymmv
Old Sep 26, 2005 | 07:12 PM
MR_EJ8's Avatar
Default Re: Will RSX injectors work in my sol??? (Laserjock)
ymmv???
i take it you have tried this?
Old Sep 27, 2005 | 09:49 AM
Laserjock's Avatar
your mileage may vary
I bought a set of used RC injectors. See the link for a pic. The input side (side closest to the electrical connector) is too big and won't fit into the D fuel rail.
Options would be to machine the injectors down (maybe) or open up the fuel rail.
https://honda-tech.com/zerothread?id=1260744
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_sol &raquo;</TD></TR><TR><TD CLASS="quote">ymmv???
i take it you have tried this?</TD></TR></TABLE>
Old Sep 27, 2005 | 06:35 PM
MR_EJ8's Avatar
cool, thanks alot.
anonnonator
Honda Civic (2001 - 2005)
22
Feb 18, 2011 04:37 AM
jdmjin
Jul 13, 2008 12:51 PM
DJaeMac
13
Aug 22, 2007 10:53 PM
