rpm signal for shift light????
yes i did a search and most of the stuff that comes up are for civics...and newer accords...i have a 97 accord LX and have an adjustable shift light...i was told it was the blue wire behind the gauge cluster...but when i tried that it didnt work...
i'd prefer to hook it up from behind the cluster so i wont have visible wires in my engine bay...
any ideas which wire to hook up the signal wire too..???
any wire diagrams...did a search on google and came up with other ****...
I did this long time ago so I don't remember anything. All I remember is I ran the wire to the engine bay, to where the connector to the stock coil. You should be able to tell if you have your car ignition wire diagram.
Is it just the tach signal you are trying to get?
If so it is the blue wire at the distributor. That is where I got the signal for my remote start. IM me if you need any more help.
ExplicitSpeed360
Dec 8, 2005 08:15 AM
egyolk
12
Aug 13, 2004 08:04 AM
