need help w/2000 civic
Old Sep 26, 2005 | 04:26 PM
importlover's Avatar
Default need help w/2000 civic
Whats up everybody. Im new here, and I need some help. I have a 2000 Civic EX coupe. Its a manual D16Y8 with 80,000 miles. I constantly go to the track. I got my time down to a 15.9, then did more work. I added a Skunk2 pro series intake manifold, ACT street clutch, ACT streetlite flywheel, Skunk2 cam gear, and Unorthodox Rcaing pulleys. When I installed my clutch and flywheel, the air assist valve solenoid was broken. It is controlled by the water pump thermostat. It was causing my car to surge at idle. I plugged the hole and it seemed to run fine, but now I cant run better than a 16.2, all damn day. So needless to say, Im pissed. No one can tell me anything except to take all the parts off and start over. In case it matters, I also have a VAFC2, an MSD ignition and a few more things. Please help
Old Sep 26, 2005 | 08:18 PM
redspiritguy's Avatar
Default Re: need help w/2000 civic (importlover)
I hate that damn valve, I cant say how many of those Ive broke. Thats not your problem though. Once you leave idle, that valve is pointless and does nothing. Your problem however is in your tuning. Since youve added so many parts, its hard to tell where the problem lies. Your clutch may not be allowing enough slip so that your motor can create the enertia to get it off the line, or your MSD may not be sparking at the right time. Also, your cam gear may be a little retarted *pardon the pun * Unfortunatly, until you go with forced induction, your really throwing you money away. Good luck bro!
Old Sep 27, 2005 | 09:50 AM
Default Re: need help w/2000 civic (spoonmectr)
thanks for the tips, ill try getting it tuned and see whats up.
boosted00ex
Dec 15, 2006 05:06 PM
boosted00ex
Nov 29, 2006 07:44 PM
civic919900
May 25, 2005 05:51 AM
TiggsCRX
Mar 5, 2004 03:32 PM
