Master cylinder and prop valve inquiry
Old Sep 26, 2005 | 04:15 PM
Seanith's Avatar
Default Master cylinder and prop valve inquiry
Does an EM1 15/16" master cylinder and proportioning valve work with 92-95 civics?
Old Sep 26, 2005 | 04:24 PM
cxSHOE's Avatar
Default Re: Master cylinder and prop valve inquiry (Seanith)
if its a pancake style (meaning its flat and has 5-6 holes) then no is the answer on the proportioning valve. the m/c will if your using the civic booster. i would go 1" integra instead of this set up.. you wont feel any difference with any 15/16..
1" is night and day... trust me i did a face plant the first stomp on my brake pedal..
:i already see litterbox pm'img me on this so im getting in before that )
Old Sep 26, 2005 | 04:27 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: Master cylinder and prop valve inquiry (cxSHOE)
:slowly closes PM box:
Old Sep 26, 2005 | 04:38 PM
cxSHOE's Avatar
Default Re: Master cylinder and prop valve inquiry (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">:slowly closes PM box:</TD></TR></TABLE>
LOL
beat you by 3 minutes
Old Sep 26, 2005 | 04:58 PM
94hatchling's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote"> i would go 1" integra instead of this set up.. you wont feel any difference with any 15/16..
1" is night and day... trust me i did a face plant the first stomp on my brake pedal..</TD></TR></TABLE>
dont mean to thread jack, but with the "1 inch" teg m/c, will it bolt up to my current brake booster (stock '94cx), or do i need to upgrade that as well? i love the way it stops now, teg knuckles and new calipers and aftermarket rotors, and stops great, but i can always go for more
Old Sep 26, 2005 | 05:02 PM
litterbox's Avatar
Default Re: Master cylinder and prop valve inquiry (94hatchling)
Integra MC = Integra Booster
Civic MC = Civic Booster.
No way around it.
Old Sep 26, 2005 | 05:12 PM
Echo7847's Avatar
1991 civic ex 4dr master cyl is 15/16 bolts up to civic booster and no need to reflare lines for teg master/booster (rs mc/bb requires no flaring).
Old Sep 26, 2005 | 05:20 PM
cxSHOE's Avatar
Default Re: Master cylinder and prop valve inquiry (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">1991 civic ex 4dr master cyl is 15/16 bolts up to civic booster and no need to reflare lines for teg master/booster (rs mc/bb requires no flaring).</TD></TR></TABLE>
yea as litterbox said civic=civic teg=teg
and this set up is not the best..... 1" 98+ integra with abs with integra booster requires no reflaring either and much better response.
i know this from going from 13/15&gt;15/16&gt; 1" i wasted money and time. do it right the first with 1" even if you dont enlarge your calipers to integra you will feel instant difference in pedal feel. like i said faceplants are a breeze..
Old Sep 26, 2005 | 05:55 PM
dantastic's Avatar
good insight.... i went with DC integra brakes and 4030 prop valve (DA integ, 4 wheel disc). i went the cheaper route with just the civic 91EX MC. i was VERY happy with the results. i had no trouble locking up the brakes. however, if i had the $$ and time, i would have gone with integ MC and BB.
**edit**
the stock 13/16 MC had an UNSAFE amount of pedal travel. if you do go with integ brakes alll around, you need to upgrade the mc
Modified by dantastic at 8:00 PM 9/26/2005
Old Sep 26, 2005 | 06:07 PM
Sliced Beard's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">you wont feel any difference with any 15/16..
:i already see litterbox pm'img me on this so im getting in before that )</TD></TR></TABLE>
bullshit, you will feel a HUGE difference over a stock unit. You can actually get a 15/16ths off of a 91 EX civic and it shoudl bolt right up but I would not use it with a stock booster.
The best setup to use is an ITR MC / BB and you do not need a different proportioning valve. The proportioning valve for drum brakes allows the pressure to equalize before pressure is applied to all 4 wheels. When you have a caliper in the rear instead of a wheel cylinder then the pressure is not alleviated by a return spring on the drum brake pads. This means that no gap is lost fromt eh pads and friction surface therefore there will not be a need for pressure equalization. Your stock prop. valve is an automatic unit and will be able to differentiate the difference and will have no adverse effect on braking. There will be no lag in rear brake application like the rumors and misinformed indivuals will tell you.
There are tons of people in Honda Challenge racing with stock drum prop valves racing with 4 wheel disc. If the prop valve adversely effected the vehicle, none of them would even touch the stock unit, except to remove it.
Old Sep 26, 2005 | 06:09 PM
Seanith's Avatar
well the reason i ask, is because i did a rear disc swap and don't need the items i mentioned. some guy is doing a rear disc swap in his 92-95 civic, so i would like to sell the em1 stuff i have to him since i don't need it. so in short the m/c will work if he keeps his brake booster? the prop valve has 4 actual holes that go into the valve..
Old Sep 26, 2005 | 06:20 PM
the EM1 MC WILL NOT workk with the civic booster!
that was stated like five times already. the only larger MC that will work is the 91 civic EX with 4 wheel disc
Old Sep 26, 2005 | 06:58 PM
Seanith's Avatar
Default Re: Master cylinder and prop valve inquiry (DirtySol)
the EM1 is a civic, so all i could see is civic = civic etc etc.. so it won't work? thats gay
Old Sep 26, 2005 | 07:02 PM
nope
I think the EM1 uses a 275 or 280 Nissin Brake Booster
Old Dec 3, 2005 | 07:44 PM
Touch's Avatar
So if you get an abs 1in. teg master cylinder, it will bolt right up to the rs 40/40 prop and teg booster? no reflaring? I just want to avoid reflaring.
Old Dec 3, 2005 | 08:21 PM
civic_driver's Avatar
if it locks the brakes so easily with the 1" master it would suck during winter time without abs
Del Sol on Steroids
Mar 5, 2008 07:52 PM
89efDUSTY
Oct 20, 2007 04:48 PM
HuskerHybrid
Mar 10, 2007 11:15 AM
mr 636
10
May 20, 2006 12:17 PM
Todapwr
Feb 18, 2004 09:10 PM
