CTR piston's and 404 cams
i was wondering i have CTR piston in a b18b block with b18b stock rods, and i am going to use 404 crower cams, and i was wondering if that is safe. what i mean is , is the lift and idration to high for these cams. or should i use another cam. i am really confused on this set up with ctr pistons, i also have a set of itr usdm pistons.
thanks so much and also im going to use the b18b head and also wondering about piston to deckhieght am i ok there. ill check these other sites also, but mite not find so if someone knows here that would be great
yea hes using -r3 which are jdm b16a pistons, the ctrs are the b16b, i forgot the user thats using the ctrs he said that he could advance his cams a long ways and not touch, but if your not sure the you could clay the motor during the build
