new guy, got some question about boosting?
Old Sep 26, 2005 | 03:16 PM
C.r.D Integ's Avatar
Default new guy, got some question about boosting?
what up peeps got a question about boosting. ill cut to the chase and spare all the bull?
How much boost can a stock B18b1 LS motor hold?
i was told 6psi and i was told 15psi which one?
I heard that that if i wanted to turn up my boost i had to get something called a linkage? something that goes near the map sensor?? lost me on that one
holla
Old Sep 26, 2005 | 04:56 PM
GSRNetics's Avatar
Default Re: new guy, got some question about boosting? (C.r.D Integ)
First off, this is in the wrong forum.
Second, just to help you out alot of people are probably going to get on your case, or just ignore this post all together.
As far as how much PSI a stock B18B1 can hold, I would say 5-6 PSI. Depending on the turbo size, maybe higher.
If you want to increase your PSI, a boost controller will be needed.
If you plan on going forced induction, and not running a fuel management system (hondata, ect..) you will have to get what is called a missing link check valve.
Stock Honda MAP sensors cannot read positive pressure. If you dont address this issue, you will throw CEL codes upon boosting, and the car may not run the way you want it too.
If you plan on turbocharging your car, please read and research first. A good start will be to go to a book store, and get a book written by Corkey Bell. They most likely will not have it in stock, and will have to order it in for you. I had mine delivered to my house.
Tells you everything you will need to know if you wish on turbocharging your car, and dispells alot of myths about turbo cars.
Once again, I can't stress this enough; read, read, read, read, and read some more. Information is your friend.
Old Sep 26, 2005 | 05:34 PM
TurdBlown Teg's Avatar
http://www.cse.uconn.edu/~yele....html
there you go
Old Sep 26, 2005 | 05:52 PM
Default Re: (kevin716)
thanks appreciate the help
which forum should i be in
Old Sep 26, 2005 | 06:33 PM
adseguy's Avatar
Default Re: new guy, got some question about boosting? (93DALS)
WTF is happening to this forum!?!? If you don't know about turbo stuff for sure, then don't speak. It's not that hard!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DALS &raquo;</TD></TR><TR><TD CLASS="quote">As far as how much PSI a stock B18B1 can hold, I would say 5-6 PSI. Depending on the turbo size, maybe higher. </TD></TR></TABLE>
No, totally false...it's Horsepower dependant if all the right pieces are used. This limit is around 280-300whp on a healthy engine. CHECK MY SIG!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DALS &raquo;</TD></TR><TR><TD CLASS="quote"> Stock Honda MAP sensors cannot read positive pressure. If you dont address this issue, you will throw CEL codes upon boosting, and the car may not run the way you want it too. </TD></TR></TABLE>
False again, the honda map sensor is a 1.75 bar meaning it can read positive pressure up to 10.4 PSI....just stick to 10 PSI on a stockmap sensor...if you need a bigger map sensor get a 3bar with the appropriate tune.
Tells you everything you will need to know if you wish on turbocharging your car, and dispells alot of myths about turbo cars. </TD></TR></TABLE>
sure sounds like you read it all the way
Once again, I can't stress this enough; read, read, read, read, and read some more. Information is your friend.</TD></TR></TABLE>
Now that I can agree with. Go to the Forced Induction forum here on HT and just start reading and searching...most all topic have been covered and you could eaily build a turbo setup, without ever leaving a post
http://www.beesandgoats.com/bo....html
http://home.mn.rr.com/keebler65/honda/
Old Sep 26, 2005 | 10:16 PM
all of your questions answered.... try a search next time
https://honda-tech.com/zerothread?id=1024174
Old Sep 26, 2005 | 10:37 PM
jdm'dc2sc61's Avatar
Default Re: new guy, got some question about boosting? (adseguy)
i agree with asdeguy. tuning is the key on how much it will be able to handle...
Hiboost 2.0
Apr 17, 2013 08:14 PM
the.hamburglar
Aug 2, 2007 02:44 PM
Crazy Cooter
Nov 4, 2003 05:02 PM
ID_ten_T
Jun 9, 2003 03:06 PM
EH2LS
Jun 5, 2003 05:53 PM
