4 wire O2 sensor??
Old Sep 26, 2005 | 03:05 PM
technine's Avatar
Default 4 wire O2 sensor??
I need to replace a primary o2 sensor off a 98 civic, can I use any 4 wire o2 sensor off any car in the 98 civic? Will it work? I know they should fit, but working with the ECU, that I don't know.
Old Sep 26, 2005 | 03:18 PM
mmuller's Avatar
Mad Scientist
Default Re: 4 wire O2 sensor?? (technine)
you can pretty much use any 4 wire honda o2; the only problem you might run into is wire lenght.
Old Sep 27, 2005 | 10:34 AM
technine's Avatar
Default Re: 4 wire O2 sensor?? (mmuller)
I was really wondering about different makes of cars like let's say a nissan 4 wire o2 sensor?
Old Sep 27, 2005 | 05:19 PM
technine's Avatar
Old Sep 28, 2005 | 11:53 AM
technine's Avatar
because a 4 wire honda o2 sensor is hard to come by at the local yard.
Old Sep 28, 2005 | 12:09 PM
mmuller's Avatar
Mad Scientist
i would go off and try it..match the wires right with the stock connector.
Now, if your trying to buy used o2's im sure you can find them here on the h-t classifies.
And a new one is like 60-70 bills.
Old Sep 28, 2005 | 04:31 PM
technine's Avatar
I guess I might just give it a try.
Old Nov 21, 2005 | 10:55 AM
technine's Avatar
Well, I pulled a four wire O2 sensor off a Mazda and hooked it up the civic that was having the problem and it worked!! No check engine light and smooth idle. The colors were different, but were pretty simular because instead of having 2 blacks, a green and a white wire the mazda O2 sensor had 2 white, 1 black and 1 grey.
It was an easy hook up because I just looked at the back of each O2 and matched the pattern (I guess whites were the ground, black was the signal and the grey was the heater wire) so I just wired it up, soldered and heat wrapped it. Worked just fine after reseting the ECU.
Old Nov 21, 2005 | 11:16 AM
mmuller's Avatar
Mad Scientist
good ****.
Old Nov 21, 2005 | 11:25 AM
technine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">good ****.</TD></TR></TABLE>
Well, lol, the owner of the civic (my girl) called me and said the check engine light came on again after a few hours of driving!! I'll will be pulling the code when I get a chance to.
Old Nov 21, 2005 | 11:46 AM
mmuller's Avatar
Mad Scientist
oh oh not good chit
leira619
Apr 12, 2010 04:38 PM
bam69icp
Oct 21, 2008 08:35 PM
