smoke coming from valve cover breather
Old Sep 26, 2005 | 02:59 PM
92civichatchsir's Avatar
Default smoke coming from valve cover breather
well for some reason there is smoke coming from my breather filter on my valve cover,is this common,also my car is sputtering lightly.need help asap
thanks
Rex
Old Sep 26, 2005 | 03:53 PM
Default Re: smoke coming from valve cover breather (92civichatchsir)
I really have no clue what it could be(also I have one of those autozone filters
Old Sep 26, 2005 | 04:22 PM
PURPLETERROR aka BIGMATT's Avatar
cracked ringlands, or you overfilled your oil
Old Sep 26, 2005 | 04:25 PM
Default Re: smoke coming from valve cover breather (PURPLETERROR)
how would I crack ringlands?also could that make it sputter
Old Sep 26, 2005 | 04:26 PM
ThatsMyEG's Avatar
that happened to my friend when he blew his head gasket.
Old Sep 26, 2005 | 06:59 PM
Default Re: smoke coming from valve cover breather (ThatsMyEG)
well took off my valve cover,there was no antifreeze and my coolant level is that same.....any ideas?
Old Sep 26, 2005 | 07:28 PM
chinese acrobat's Avatar
Burning oil is a posibility.
Old Sep 26, 2005 | 07:33 PM
think it might be my piston rings
Old Sep 26, 2005 | 09:02 PM
peacexisxfree's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civichatchsir &raquo;</TD></TR><TR><TD CLASS="quote">think it might be my piston rings</TD></TR></TABLE>
that's exactly what that is. i know some people wont even put breathers on that line out. instead they have a clear, plastic tube. this informs them of any blowby, or bad rings...this can be caused by extreme hard driving , not having enough oil and revving it out, not having enough oil, period and having a plain ole' high mileage motor. i wish you luck. oh, and yes, this can cause major loss of power, as compression drops.
Old Sep 26, 2005 | 09:08 PM
DaZDiLI's Avatar
what would cause his piston rings to fry? lack of oil? over revving?
Old Sep 27, 2005 | 07:48 AM
dpkelly's Avatar
Default Re: (DaZDiLI)
Compression rings may be good but the oil rings may have gone bad. Also check your PCV valve.
Old Sep 27, 2005 | 08:43 AM
Default Re: (dpkelly)
where is the pvc valve on a gsr?
Old Sep 27, 2005 | 10:07 AM
dpkelly's Avatar
Default Re: (92civichatchsir)
If I'm not mistaken it should be in the hose that comes from the intake manifold and goes into the valve cover. It should be inserted into the valve cover. On a d15b7 like mine, the PCV valve is connected to an oil breather on one end that is connected to the block below the intake manifold. On the other end it's connected to a hose that runs to the intake manifold.
b18psi
Jun 4, 2007 09:40 PM
huepowered
Apr 4, 2006 12:10 PM
tnsxsear1
Nov 20, 2003 07:08 PM
type Gendy
15
Sep 26, 2003 02:15 PM
boostdB16a
Aug 8, 2003 08:28 AM
