Valve Adjustment help
Old Sep 26, 2005 | 02:36 PM
evil civic's Avatar
Default Valve Adjustment help
my valves need to be adjusted on my 95' ls swap. Is this easy to do. what tools do i need and where can i find the measurements they need to be adjusted too. please help me out and give me a how too. i need to learn how to do this stuff. thanks in advance.
Old Sep 26, 2005 | 03:40 PM
evil civic's Avatar
Default Re: Valve Adjustment help (evil civic)
TOP
Old Sep 26, 2005 | 06:09 PM
jfoster's Avatar
This is for a Vtec motor but still gives you an good idea of the process ....
http://www.c-speedracing.com/h...m.php
Get yourself a helms manual and you should be in good shape.
Old Sep 26, 2005 | 08:12 PM
redspiritguy's Avatar
you need the appropriate feeler gauges, screwdriver, 12mm wrench, 19mm socket, and 1/2" ratchet. Check online for lash specs. adjust the valves at TDC for each cylinder starting with #1 then, 3, 4, 2. Turning the motor 90 degrees on the cam each time
Old Sep 27, 2005 | 04:26 AM
evil civic's Avatar
Default Re: (spoonmectr)
thank you so far
prelude1897
Jun 26, 2005 01:58 PM
EG_Jefro
Oct 26, 2004 04:34 PM
General george
Aug 2, 2004 01:00 PM
Wicked_CRX
Jul 16, 2003 04:38 PM
f22btwincam
Dec 3, 2002 05:11 AM
