Quick Question: would 195-60-15 fit integras?
someone that i know is selling size : 195-60-15 tires for dirt cheap i am just wondering if it would fit on my integra.. drop about 2inch with 15's now and camber kit
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SingeBgd »</TD></TR><TR><TD CLASS="quote">yes it would, thas actually the size tires that i had when i bought my teg</TD></TR></TABLE> is your car lowered?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">That'll be pushing it with a 2 inch drop. I'd drop back to some 195/55/15's.</TD></TR></TABLE>
really? damn this stupid thing is getting to my nurves
anyone out there knows the exact answer for this.. plz reply thanks
with a 2" drop you might not be rubbing when you're just sitting there or going down a smooth surface, but the tire will definitely interfere when you hit a bump. and when you hit a bump and interfere, the tire will be getting gouged by whatever it hits (the fender and/or plastic fender liner).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman »</TD></TR><TR><TD CLASS="quote">with a 2" drop you might not be rubbing when you're just sitting there or going down a smooth surface, but the tire will definitely interfere when you hit a bump. and when you hit a bump and interfere, the tire will be getting gouged by whatever it hits (the fender and/or plastic fender liner).</TD></TR></TABLE>
so it won't fit then.. unless i raise my car a bit huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaChiLa Leader »</TD></TR><TR><TD CLASS="quote">so it won't fit then.. unless i raise my car a bit huh?</TD></TR></TABLE>
pretty much. it will look like it will fit, but you'll have rubbing problems and they will get worn down very quickly in the spots where they rub, necessitating new tires again. consider it a temporary solution if your current tires are showing the cords and you need new ones like yesterweek.
pretty much. it will look like it will fit, but you'll have rubbing problems and they will get worn down very quickly in the spots where they rub, necessitating new tires again. consider it a temporary solution if your current tires are showing the cords and you need new ones like yesterweek.</TD></TR></TABLE>
OH man.. that's gay... alright thanks for the info..i will just tell him i will pass
thanks
thanks
