hook fan up to a switch
Old Sep 26, 2005 | 01:01 PM
slowassciv33's Avatar
Default hook fan up to a switch
like the title says...whats the best way to do this...as of right now the fan is wired straight to the battery and was always on......or can i wire it up to a key activated wire like the ingniton wire but is ther one under the hood??? need help asap
Old Sep 26, 2005 | 02:21 PM
Default Re: hook fan up to a switch (slowassciv33)
BUMP please
Old Sep 26, 2005 | 02:28 PM
Spectrum24x's Avatar
Probably the easiest way to do it is wire it up to the radio, so whenever you have your radio on the fan is on.
You could do a physical switch, but if you ever forget to flip the switch, you could have serious problems
Old Sep 26, 2005 | 02:35 PM
BlackDAy's Avatar
Default Re: hook fan up to a switch (Spectrum24x)
i have a switch to activate my fans. its pretty convenient. but like Specturm24x says, forgetting to turn it on could be bad...
Old Sep 26, 2005 | 02:48 PM
Bob Boberson's Avatar
you could just do it right and hook it up to a thermostat
Old Sep 26, 2005 | 03:08 PM
calxtreme's Avatar
if you were to hook it up to a switch, use a relay so that all the current does not run through the switch. Hooking up to the accessory wire woul allow it to turn on when you're driving, but then it would also stay on if you were to just sit in your car with your engine off while listening to the radio or something.
Old Sep 26, 2005 | 03:11 PM
Default Re: hook fan up to a switch (Bob Boberson)
i would hook it up to teh thermastat but its all like butch and choped
Dee9222
Mar 18, 2014 01:34 AM
98ej8coupe
Jul 30, 2008 10:07 PM
TylerB
Jul 11, 2004 08:02 PM
4DRmafia
10
Jun 20, 2004 10:49 PM
st0nedstoopid
Jul 11, 2003 12:19 AM
