STR Throttle body, Anyone have probs?
Old Sep 26, 2005 | 12:23 PM
f1 vtec's Avatar
Default STR Throttle body, Anyone have probs?
Hey, just wanted to know if any1 had any idle problems/ any problems at all with the 70mm STR TB?
Old Sep 27, 2005 | 04:30 AM
f1 vtec's Avatar
Default Re: STR Throttle body, Anyone have probs? (f1 vtec)
bump
Old Sep 27, 2005 | 04:56 AM
boost93's Avatar
I had a problem with idling, and it was because the gasket does not have a hole cut in it for the idle air control valve. After I cut a hole in it, it idled perfect.
Old Sep 27, 2005 | 06:29 AM
iakona's Avatar
yep. no problems here either. just make sure all the proper passages are available for air for the ecu and you'll be fine.
if you're worried about the FITV, you won't miss it.
Old Sep 27, 2005 | 07:27 AM
f1 vtec's Avatar
Default Re: (iakona)
Well i have the STR TB on my car at the moment, just installed it. I cut the hole for the IACV too. But its not idling at all.
Old Sep 27, 2005 | 07:29 AM
iakona's Avatar
did you check the set screw with the allen head that acts as teh throttle stop for when the plate is closed?
Old Sep 27, 2005 | 07:40 AM
f1 vtec's Avatar
Yea i adjusted that didnt make a difference. Im gonna try adjust the TPS. Any other things i should know of
Old Sep 27, 2005 | 07:50 AM
iakona's Avatar
not that i can think of. good luck!
EVS90
Mar 16, 2014 04:27 PM
Ur 2 Slow 4 J
Dec 30, 2005 07:49 PM
bryan99si
11
Sep 8, 2005 09:35 PM
Shft@9GSR
Nov 15, 2002 11:21 AM
