black window trim on 5th gen
Old Sep 26, 2005 | 12:22 PM
diegospecaccord's Avatar
Default black window trim on 5th gen
does anyone know where i can get the black window trim bcuz i do not like the chrome trimming.....
Old Sep 26, 2005 | 12:58 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: black window trim on 5th gen (diegospecaccord)
DIY
Old Sep 26, 2005 | 01:00 PM
Default Re: black window trim on 5th gen (Vt4cPwn35)
i dont want to do DIY i want the real deal......
Old Sep 26, 2005 | 01:03 PM
213374U's Avatar
0x5359-0055
Community Builder
I don't think they even came in black. You could try a DX but I'm pretty sure those had chrome as well.
DIY is probably your only option
Old Sep 26, 2005 | 01:20 PM
Old Sep 26, 2005 | 03:16 PM
fw190bvi's Avatar
on certain colors, the chrome pieces look better
Old Sep 26, 2005 | 03:36 PM
kevinthefawker's Avatar
1 option is to find a dx around at the junk yards 94-97 or use electrical tape and go around and tape up the chrome or just mask eveything off and paint it black
Old Sep 26, 2005 | 03:54 PM
fknslmd's Avatar
Default Re: (kevinthefawker)
the dx mouldings are black, i got them for my lx at the dealership. it was like 312$ for all of them. don't bother looking in a junkyard because you can't remove them without breaking all the clips, they're made to be replaced new.
Old Sep 26, 2005 | 07:43 PM
asianalbutt's Avatar
i have a dx :D
Old Sep 26, 2005 | 07:46 PM
gianinline's Avatar
Default Re: (fknslmd)
..there is a way to remove them without breaking, there's a proper way to release the clips from the car...
Protect with tape around your doors and stuff.... make sure you get everything protected, and spray paint it!!!
...But I think the chrome piece gives a nice touch to the accords....
Old Sep 26, 2005 | 09:35 PM
how long did it take?
Old Sep 27, 2005 | 07:35 AM
CB7.v2's Avatar
i had my 4th gen recently repainted and i took off all the chrome moldings to prevent overspray. i just sprayed the trim with black paint i already had. if i had to do this again, i would not do it because many of the mechanical fasteners broke. although they can be replaced, they are not cheap and always have to be special ordered. if you want black trim, do a good tape job and paint them while on the car. for some, you can slip small strips of somewhat rigid paper to speed things up and then quickly tape up any portion of the car that is needed. don't use enamel paint because it's thick; try a low gloss or flat paint. you may have to scuff the metal with some wet-dry sandpaper first and/or use a coat of adhesion promoter before painting.
Old Sep 27, 2005 | 11:06 AM
P_Adams's Avatar
Buy yourself a set from Honda and have them either powder coated or anodized locally. That way you can chose any color you want, and it will be durable.
I have not run into an aftermarket vendor yet that's offering these
Look in your local Yellow Pages under coatings, finishes or plating (chrome etc)
P
Old Sep 27, 2005 | 02:09 PM
drktorn's Avatar
Default Re: black window trim on 5th gen (P_Adams)
im a noob here, but i dont recommend you guys use a rattle can on your car? i rather leave them alone then use a rattle can. do it do it right.
Old Sep 27, 2005 | 03:13 PM
brads94accord's Avatar
theres nothing wrong w/ a little rattle can..i rattle canned the little chrome trim piece above my license plate. i used some gloss black radiator paint made by eastwood..comes out w/ a really good finish..on a piece as small as the little window trim theres not that much room for error.
homer5400
Sep 4, 2009 12:48 PM
EG9_808
11
Sep 1, 2006 08:08 PM
LordoftheAccord
Mar 14, 2003 12:40 PM
slowexcoupe
14
Nov 15, 2002 09:23 AM
