GT in B16A - Best Choice!
Old Sep 26, 2005 | 11:34 AM
VTI Brazil's Avatar
Default GT in B16A - Best Choice!
I did a search before but nothing match...
I was wondering if there is anyone running a GT30R, GT3071R or GT 2871R on a B16A stock bore.
How would the spool time of this turbo be on a B16?
This is for a street/strip daily driven 93 Hatchback.
Block is semi build stock bore with 9:1 compr. pistons and eagle rods, arp.
My goal is to get about 450-550whp when I'm at the strip and 400whp daily.
Let me know what you think
Old Sep 26, 2005 | 12:35 PM
BlackT5's Avatar
Go with a the GT30R. I can't see the other turbos you listed reaching your power goal.
Old Sep 26, 2005 | 07:54 PM
VTI Brazil's Avatar
Default Re: (BlackT5)
I think the same.
Anyone to say something more!?
Old Sep 26, 2005 | 07:59 PM
11psiTurboSI's Avatar
Default Re: (VTI Brazil)
I 2nd the GT30R
andysila's Avatar
i am currently building the same thing. i would say go with a gt28rs but your goal is a little higher than what it would support. so i say go with the GT30R, same thing i'm goin with.
Old Sep 26, 2005 | 08:41 PM
TheShodan's Avatar
Moderator
Default Re: (andysila)
Or perhaps even my GT3257, or GT35E. The GT30R will reach 400whp at over 16psi with the current setup you are configuring.
Old Sep 26, 2005 | 09:00 PM
mochasi's Avatar
Default Re: (TheShodan)
what about the 3071r??
Old Sep 27, 2005 | 12:42 AM
VTI Brazil's Avatar
I think GT30R will give to me what I'm looking for...
GT3071R is a litlle bit smaller than GT30R and will not give to me 550whp with good VE.
Old Sep 27, 2005 | 12:56 AM
flip1199's Avatar
goin by garrett website the gt30r is good for about 500hp, but i've been told they under-rate there turbo's so i don't know.. ever ponder the gt35r?
Old Sep 27, 2005 | 03:11 AM
B18C5civic's Avatar
Default Re: (flip1199)
I have virtualluy the same build, the guys at full race have advised me the GT3037.
Old Sep 27, 2005 | 06:24 AM
andysila's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">goin by garrett website the gt30r is good for about 500hp, but i've been told they under-rate there turbo's so i don't know.. ever ponder the gt35r?</TD></TR></TABLE>
he's got a point, ive seen a b16 (em1) with this kind of setup, http://www.turboed.com , his ride is pretty damn clean. you should go to that webiste and check out the videos, if that doesnt work then go to streetfire.net and search 'turboed' to find some more videos.
hes runnin a gt35r 20 psi on pump. i just cant find the hp numbers. and im sure it was his daily driver too.
Old Sep 27, 2005 | 06:43 AM
alpha's Avatar
Default Re: GT in B16A - Best Choice! (VTI Brazil)
A GT2871R will not make 550whp or even 500whp. I would say that turbocharger will make 410whp max on a 1.6 liter B16a. Your best bet would be a GT3076RLS with a large A/R turbine housing.
I refer to the GT30R as the GT3076R. It has a 76mm exducer on the compressor wheel. The GT30RLS / GT3076RLS with a larger turbine A/R will get you close but wont get you there.
Are you running meth in this car?
Good luck
Salvatorie
Oct 29, 2011 07:15 PM
ERKK
Mar 26, 2010 12:42 PM
integrawow
Feb 19, 2007 05:19 PM
gulf imports
Jun 20, 2004 12:31 PM
