S2000 Injectors
Old Sep 26, 2005 | 10:31 AM
BLK99VTECR's Avatar
Default S2000 Injectors
Does anyone have any experience on how these perform on a B-Series wit cams and stuff?. Im asking more cause I was gonna get RC310 which go for like 200 somthing but then I heard S2Ks are 370cc and can be gotten for under a little over 100.
Old Sep 26, 2005 | 10:57 AM
Used2beAb16's Avatar
Default Re: S2000 Injectors (BLK99VTECR)
290 cc lude injectors will work well, and alot of people go with them vs. the 310's. Im sure u knew that though i dont know much about the s2k injectors.
bump
Old Sep 26, 2005 | 11:17 AM
BLK99VTECR's Avatar
Default Re: S2000 Injectors (Used2beAb16)
ok I will look into those
Old Sep 26, 2005 | 04:44 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
i'm using s2000 injectors because i'd rather use oem when i can, they work great. not direct swap though. you need to modify the fuel rail (10 min's). i had to use the taller injector/manifold seals.
Old Sep 26, 2005 | 05:17 PM
RudeBwaiSi's Avatar
Where is your dizzy?
Old Sep 26, 2005 | 05:50 PM
Default Re: (RudeBwaiSi)
it's on now. i took the pic while i was working on a couple things so it just wasn't back together.
Old Sep 26, 2005 | 07:37 PM
BLK99VTECR's Avatar
Default Re: (not so civic)
when you modify the fuel rail to make them fit, what else will u need to fit them?. Also if i bought a aftermarket fuel rail would i still need to modify it?
Old Sep 26, 2005 | 08:56 PM
Default Re: (BLK99VTECR)
the rail basically needs to sit toward the head more about 5-6mm lower. if you don't want to hack the rail, then see if you can shave the mounting points on the manifold down. what kind of manifold are you using? it was easier for me to setup a type r fuel rail and i did have a b16, but i would have had to cut and make some brackets to make it work.
Old Sep 27, 2005 | 07:07 PM
BLK99VTECR's Avatar
i have a skunk2 manifold
Old Sep 28, 2005 | 05:35 AM
LSVTEC 91 Civic's Avatar
Banned
FYI...
OBD1 peak and hold prelude injectors are 340cc
OBD2 saturated prelude injectors are 290cc
and no modding, they plug and play.
Old Sep 28, 2005 | 09:07 AM
BLK99VTECR's Avatar
Default Re: (LSVT3K 91 C1V1C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C &raquo;</TD></TR><TR><TD CLASS="quote">FYI...
and no modding, they plug and play. </TD></TR></TABLE>
so what would be the better ones to get
Old Sep 28, 2005 | 09:12 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLK99VTECR &raquo;</TD></TR><TR><TD CLASS="quote">so what would be the better ones to get</TD></TR></TABLE>
Do you have a resistor box? If so get the OBD1's. If you don't have a resistor box find some OBD2s
Old Sep 28, 2005 | 09:14 AM
Player5530's Avatar
I believe the OBD 1 injectors are best to get. I was looking in to getting these injectors.
Old Sep 28, 2005 | 01:28 PM
onebadld's Avatar
Default Re: (Player5530)
so what size are s2000 injectors?
Old Sep 28, 2005 | 06:09 PM
HONDABROMANDUDE's Avatar
Default Re: (onebadld)
360cc's.
Old Sep 28, 2005 | 06:41 PM
hybridpatient95's Avatar
you can always use h22 injectors 345's
Old Oct 1, 2005 | 11:35 PM
high_revs's Avatar
Default Re: (frankenfiend 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenfiend 04 &raquo;</TD></TR><TR><TD CLASS="quote">you can always use h22 injectors 345's </TD></TR></TABLE>
the obd1's....now im assuming he needs obd2 since he mentioned s2000 which only came out in the obd2 years so stock h22 obd2 injectors are 290cc's
EJ8 GSR-T
Jan 13, 2014 09:35 AM
Quickridez_3
Aug 18, 2007 01:22 PM
92TypeR
Apr 7, 2005 08:58 AM
topspeed86
Mar 20, 2005 03:43 PM
