Need expert suggestions for improved gas mileage...
Old Sep 26, 2005 | 10:25 AM
n1div's Avatar
Default Need expert suggestions for improved gas mileage...
I recently bought a 1990 Integra for my gf's father and did the usual maintenance items:
New Plugs/Wires/Distributor Cap
Cleaned IM/Injectors/Throttle Body/FITV/IAC
New Intake Filter
New Fuel Filter
New O2 sensor
New PCV valve
But somehow, he is still averaging only 16mpg in the city. I know this can't be right. Anything else I should look for? The guy I bought it from had a recently newer head so valves should've been adjusted then. I was thinking of checking the EGR but not sure if this makes a big difference in fuel mileage.
Old Sep 26, 2005 | 10:38 AM
low430's Avatar
Default Re: Need expert suggestions for improved gas mileage... (n1div)
tell him to keep his foot off the gas, I get 16 when I drive around at WOT all day long
Old Sep 26, 2005 | 10:59 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1div &raquo;</TD></TR><TR><TD CLASS="quote">I recently bought a 1990 Integra for my gf's father and did the usual maintenance items:
New Intake Filter
New Fuel Filter
New O2 sensor
New PCV valve
But somehow, he is still averaging only 16mpg in the city. I know this can't be right. Anything else I should look for? The guy I bought it from had a recently newer head so valves should've been adjusted then. I was thinking of checking the EGR but not sure if this makes a big difference in fuel mileage.</TD></TR></TABLE>
wow that sucks, well for one if its not an automatic then it doesnt have an EGR valve. if the cat is really clogged that could cause part of the problem, but you would also notice a drivability problem (IE hesitation). What is the timing set at?
Old Sep 26, 2005 | 02:03 PM
n1div's Avatar
He does have a lead foot sometime but he's been driving like a granny lately to see if it would make a difference.
Yes it is an automatic so it does have the EGR valve. Clogged cat seems doubtful since driveability and power are fine. I will check the timing but I don't think it would affect the fuel mileage that much.
Old Sep 26, 2005 | 02:09 PM
PnoyJeff's Avatar
Default Re: (n1div)
using good gas?
Old Sep 26, 2005 | 03:15 PM
temp's Avatar
Default Re: (n1div)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1div &raquo;</TD></TR><TR><TD CLASS="quote">He does have a lead foot sometime but he's been driving like a granny lately to see if it would make a difference.
Yes it is an automatic so it does have the EGR valve. Clogged cat seems doubtful since driveability and power are fine. I will check the timing but I don't think it would affect the fuel mileage that much.</TD></TR></TABLE>
diu if he is off like 2-3 teeth it will GREATLY affect gas mileage
Old Sep 27, 2005 | 06:59 AM
n1div's Avatar
Default Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">diu if he is off like 2-3 teeth it will GREATLY affect gas mileage</TD></TR></TABLE>
Sorry, I should've clarified that I was talking about ignition timing. Cam timing is spot on. Anyone else experience something similiar?
Old Sep 27, 2005 | 10:38 AM
crx_88_si's Avatar
dirty fuel injector?
Old Sep 27, 2005 | 10:42 AM
MN_BB4_Si's Avatar
Default Re: (n1div)
I had the same problem with my DA. I did all the routine maitenence that you said you did, checked my cat, checked my cam timing, and lone behold. it was my injectors. they were fu*ked as all hell. try running a couple tanks of gas with lucas injector cleaner. that helped alot. now im average 25/30mpg street/highway. Good luck with that though.
Old Sep 27, 2005 | 01:17 PM
mstolars's Avatar
Some shops also can do the injector cleaning for like 50 bux or so. They run injector cleaner directly into the fuel rail to clean the injectors. But I guess you could try the in the tank stuff. Did you use the seafoam yet? That will sometimes work miracles.
Old Sep 28, 2005 | 08:44 AM
n1div's Avatar
Default Re: (UNEMPLOYED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNEMPLOYED &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem with my DA. I did all the routine maitenence that you said you did, checked my cat, checked my cam timing, and lone behold. it was my injectors. they were fu*ked as all hell. try running a couple tanks of gas with lucas injector cleaner. that helped alot. now im average 25/30mpg street/highway. Good luck with that though.</TD></TR></TABLE>
I thought it was my injectors too so I replaced them with low mileage injectors and still didn't help. I'm thinking of checking my fuel pressure just to make sure my regulator isn't faulty or anything.
Acirimis
Dec 24, 2016 07:04 AM
HeikDiesel
Apr 16, 2008 05:53 AM
redDAinteg
Jan 29, 2008 01:05 PM
jdadams12
Feb 22, 2007 09:24 AM
