99 Civic EX - Slight and quick loss of power with steady throttle.
Probably nothing to worry about, but I like working on my car and want to make it run flawlessly.
Whenever I have steady throttle on the highway, I frequently get a slight loss of power. It feels like I'm taking my foot off the gas pedal for a half second. Got any ideas on what it could be?
I have brand new spark plugs, relatively new wires that have worked well in my old civic as of a month ago, brand new O2 sensors.
The only thing I can think of is that it's the distributor rotor which looks a bit shitty. But I'm up for suggestions so I can learn :D
Re: 99 Civic EX - Slight and quick loss of power with steady throttle.
Have u done any tune up?
new cap and rotor..
Spark plugs gapped correctly?
Fuel filter ever been change?
Injectors clean?
new cap and rotor..
Injectors clean?
Fuel filter more than likely.
Had a similar symptom as described in gf's car (98 civic,) had fuel filter replaced and it's been fine ever since. Go ahead and replace the cap and rotor too, or replace entire dizzy if red dust ia throughout. Preventative maintenance is key.
Premium Member
I have noted this infrequently and randomly on my car.
Of course you should make sure the basics like cap/rotor & fuel filter have been serviced.
I did not get much in the way of response on my inquiry: https://honda-tech.com/forums/hybrid...ic-si-3284320/ but TPS was mentioned, along with IACV
This thread made me think about the TPS: https://honda-tech.com/forums/honda-...olved-3289765/
F20E36
09-12-2016 10:05 AM
deerman2701
12
06-22-2009 12:09 PM
