lowering to 1.25 inches. HELP!
Old Mar 1, 2002 | 09:02 PM
GSblueRacing's Avatar
Default lowering to 1.25 inches. HELP!
Ok, I have done pretty much some research on the spring and shocks. Im thinking(yep just thinking, not yet decided) of dropping my teg to 1.25" with comptech springs and tokico illuminas. I know I will have to get an alignment but do I need a CAMBER kit for this drop?
and if I do get the tokico illuminas, what setting shock I set the shocks?
Old Mar 1, 2002 | 09:19 PM
justinCO's Avatar
Default Re: lowering to 1.25 inches. HELP! (GSblueRacing)
The way to *know* if you need a camber kit is to go have an alignment done after the installation of the springs/shocks. That will give you an accurate measurement of where your camber stands and how it needs to be adjusted, if any. After I dropped my car, approx. 2", I took it in for alignment and found out my front right wheel was out of wack a bit. The rest of my wheels were fine, so you just have to get the alignment and see how it comes out. On my Illuminas I started running them at the 3 setting.
Justin
Old Mar 1, 2002 | 09:23 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Most likely you won't need a camber kit but you'll need to get an alignment. I have the Eibach ProKits with koni's and it's about an inch or more drop (not much more). I have never needed a camber kit.
Old Mar 1, 2002 | 09:30 PM
Default Re: lowering to 1.25 inches. HELP! (Gee3)
another thing, when should I get them aligned after the drop? some people say right away, some say after 2 weeks. Do I have to adjust the headlights too?
91(si)hatchey
Sep 21, 2006 09:01 PM
Quiks66
Sep 26, 2004 01:11 PM
OneZero1010101
May 29, 2004 03:51 AM
97Alex
Apr 14, 2004 04:16 PM
Bishop Don Shizzle
Mar 20, 2003 10:56 AM
