crankshaft pulley?
Old Sep 26, 2005 | 05:44 AM
Slow as piss's Avatar
Default crankshaft pulley?
sorry i dont have much time to do a search through the archive threads, but i am in teh middle of replacing my timing belt on my 1990 Honda CRX DX and i have tried three different impacts to try to get the cranshaft pulley bolt off so that i can continue the break down.
is there a special tool required to remove this bolt without rounding it off?
-noel
Old Sep 26, 2005 | 06:41 AM
dr_latino999's Avatar
Default Re: crankshaft pulley? (Slow as ****)
Impact, impact, impact
I eventually gave up on trying to take off my crank pulley by muscle power alone and took the block to an autosalvage yard where they hit the bad boy with a 500ft/lb impact. With this, it still took 45 seconds of constant beating to remove the sucker.
Old Sep 26, 2005 | 07:12 AM
b18_crx's Avatar
Default Re: crankshaft pulley? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Impact, impact, impact
I eventually gave up on trying to take off my crank pulley by muscle power alone and took the block to an autosalvage yard where they hit the bad boy with a 500ft/lb impact. With this, it still took 45 seconds of constant beating to remove the sucker.</TD></TR></TABLE>
EITHER THAT or a breaker/cheater bar works every time
Old Sep 26, 2005 | 08:43 AM
Default Re: crankshaft pulley? (b18_crx)
That works if the pulley has been removed recently, if not, you are boned. It does help to have the engine in the car, if you take out the motor and then want to remove the crank pulley......we're sorry.
Old Sep 26, 2005 | 09:01 AM
tyro's Avatar
24" long 1/2" breaker bar, 1/2" six point socket, 20" long 1/2" extension and a 4-foot section of pipe makes easy work out of it.
I found that it was best to rest the part of the extension nearest the breaker bar on a jack stand as a pivot point.
good luck
Old Sep 26, 2005 | 09:14 AM
.Unknown.'s Avatar
Aww Man.... I hope i don't have all this Trouble... I have to Change my T-Belt and Tensioner... =[
Old Sep 26, 2005 | 05:41 PM
thanks for all the help, i ended up borrowing a 3/4 impact and lubed the **** out of the base of the bolt, it came off pretty easily with that mammoth impact.
-noel
Old Sep 26, 2005 | 06:07 PM
coot_er's Avatar
Default Re: (jason_alt)
i was using my uncle's 800 lb impact on our cheap 8 gallon compressor. it took about 10 times of pulling the trigger until the PSI was down to 60 and letting the tank refill until it finally came off. ive also heard that bumping your PSI to 125 helps, but i never did that.
zeroptzero
Jan 6, 2019 07:24 PM
zrs6v4
Feb 16, 2016 11:57 AM
jdm_vtec
13
Dec 3, 2006 05:06 PM
Imprezn
Aug 13, 2003 12:01 PM
Milano97
Jun 2, 2002 04:59 PM
