bent valves? car sounds like a subaru
hey...i missed shifted really bad at the track this sat. (around 10,000 rpm) and after i got back to the pit area my car started to sound like a subaru. the exhaust had a sound like a stop and go stop and go...its like a im gasing it and letting go(sounds like a subaru w/ a exhaust)....but my rpm is still at 8? my friend said i might have slightly bent my valves....soo please help me
Modified by g1itchgsr at 7:34 AM 9/26/2005
thanks...im trying to look for another head right now...but i might just swap in a ls motor for now, im low on funds after buying spoon wheels and exhaust
Guest
Posts: n/a
Bent valves, that's just one of the issues bro. For sure it's not just one valve, but a few. Also, your cylinder will have an issue, probably because the oil jet, inside the engine, it's messed up. Same thing happened to my ride. Ended up blowing up my engine. When I went to put it on this Sat after spending like $1500 fixing it, I realized that it was messed up because the oil jet was fucked up. If it's a GSR then nevermind, then it's just your valves. I got lucky and was able to drive for over an year like that but don't take a chance. You'll get screwed like me
If you have more questions, just PM me I'll tell you more details on what happened but yea, basically the same story, I miss shifted and hit around 12k rpm and thats how my car sounded. Just like a WRX
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">A B16 head just might help you out. </TD></TR></TABLE>
not if he fucked up his block like I did.......
yea...i hope nothings wrong w/ the block....if anything ill swap in a ls and say good bye to vtec for a while
ill tell u guys when i open her up
ok, i searched around and this is the closest thread i could find. to start off my car also sounds like a WRX along with a few other problems like it doesnt want to accelerate correctly..like it is struggling and when i stop at lights the rpms go so low it will stall.
4 people have looked at it and said i needed a head gasket, another says its bent valves,the other says it sounds like a fuel issue. im not sure what to think
if i had the money id just throw a swap in it but i just cant afford that right now.
its a 95 del sol, d16z..1.6 sohc vtec
you should be able to hear the ticking of the valves somewhat. and the noise will become more rapid as rpm increases. do a leakdown test. i cracked a ringland on 2 pistons and that made my car sound like a subaru lol.
dantamparacer
May 1, 2010 04:29 AM
lilxvtecxpwr
11
Sep 17, 2002 05:58 PM
