seafoam on a high mileage motor?
Old Sep 25, 2005 | 10:31 PM
civiccoupe94's Avatar
Default seafoam on a high mileage motor?
my friend has a cx motor with 230k on the motor, would seafoaming it casue it to wear out faster? and would doing so make it run a bit smoother and possibly better acceleration?
Old Sep 25, 2005 | 10:33 PM
RCautoworks's Avatar
Default Re: seafoam on a high mileage motor? (civiccoupe94)
seafoam is unpredictable, I have seen it do some good things, but I have also seen some bads things happen when using it.
Use water, it works, do a search if you don't believe me. Basically steam cleaning your engine, all naturally though.
Old Sep 25, 2005 | 10:38 PM
yea.. my buddie is pretty broke.. still in high school but still wants to get some decent power in his hatch. will seafoam like blow a motor up since it raises the temperature?
Old Sep 25, 2005 | 10:40 PM
Default Re: (civiccoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">yea.. my buddie is pretty broke.. still in high school but still wants to get some decent power in his hatch. will seafoam like blow a motor up since it raises the temperature?</TD></TR></TABLE>
Why would seafoam raise the temperature, you need to stop posting and search more.
Seafoam is not going to give you any huge power gains
Old Sep 25, 2005 | 11:25 PM
94hatchling's Avatar
Default Re: (90blackcrx)
in my mustang, my hatch, a buddies accord, and my brother-in-law's 140,000mile escort, worked well as far as idle, and smoother acceleration. it removes all the carbon buildup etc inside the intake and in the head. 90blackcrx is correct, you wont see any power gains, but as for better idle and smoother idle, this is true. i havent seen anything bad come from it, nor heard anything bad from it. just follow the instructions.
EDIT: and all the damn green and underlined words is driving me up the wall
Old Sep 26, 2005 | 12:31 AM
1995Ex_Sedan's Avatar
If it isnt broken, don't fix it. I've heard good and bad about seafoam. I for one wouldn't let it touch my car with 205k. -Shrugs-
Old Sep 26, 2005 | 12:33 AM
Eyal 951's Avatar
Default Re: (1995Ex_Sedan)
i seefoamed my 175K CX motor (I dunno why either)
nothing really happened, its cleaner though. Technicaly, if it cleans your pistons well, you can lose power. Cleaning off the carbon build up will lower compression.
Old Sep 26, 2005 | 08:41 AM
93CivicSI's Avatar
I ran seafoam through my 180,000 miles 93 Si with no problems.
Old Sep 26, 2005 | 11:46 AM
godzilla_juice's Avatar
Try this http://www.amsoil.com/storefront/aef.aspx
Old Sep 26, 2005 | 11:55 AM
sockvtec's Avatar
i had 272k on mine when i seafoamed it, and it helped me alot...and the engine is still flawless
Old Sep 26, 2005 | 03:17 PM
Bob Boberson's Avatar
Default Re: seafoam on a high mileage motor? (sockvtec)
all seafoam is a decarbonizer and if used properly it is not going to hurt anything
Old Sep 26, 2005 | 03:44 PM
peacexisxfree's Avatar
Default Re: (94hatchling)
there's a way to get rid of that...let me find it...
go here: http://www.vibrantmedia.com/wh...t.com and go down to the bottom of the screen. click disable and you are on your way to unannoying h-t browsing.
Old Sep 26, 2005 | 03:59 PM
Cypher0117's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchling &raquo;</TD></TR><TR><TD CLASS="quote">EDIT: and all the damn green and underlined words is driving me up the wall </TD></TR></TABLE>
don't know anything about seafoam but had to second that ^^^^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peacexisxfree &raquo;</TD></TR><TR><TD CLASS="quote">there's a way to get rid of that...let me find it...
go here: http://www.vibrantmedia.com/wh...t.com and go down to the bottom of the screen. click disable and you are on your way to unannoying h-t browsing. </TD></TR></TABLE>
AND THANK YOU ^^^
turboteg90
Sep 4, 2008 03:09 PM
fatboy01
Honda Motorcycles
16
Mar 12, 2008 10:38 AM
nvmeplz
135
Dec 29, 2006 03:20 PM
fe519
Feb 11, 2004 01:22 PM
