car doesn't go above 60mph on uphills unless I floor it
Old Sep 25, 2005 | 10:29 PM
byronl's Avatar
Default car doesn't go above 60mph on uphills unless I floor it
Hey guys, i've been having this problem where I'm cruising at 60mph and when I add more gas the car doesn't seem to respond, it just stays at 60mph doesn't go any faster or doesn't slow down. When I add even more gas nothing will happen until I get to a point when I press on the gas down enough that the car will suddenly accelerate. I can really feel it whenever I'm driving on to the freeway onramp or when i'm driving uphills.
Old Sep 25, 2005 | 10:30 PM
M12's Avatar
M12
Default Re: car doesn't go above 60mph on uphills unless I floor it (byronl)
Its called gravity and it pulls your car down to the earth.
IBTL
Old Sep 25, 2005 | 10:33 PM
Kyles ej1's Avatar
Default Re: car doesn't go above 60mph on uphills unless I floor it (M12)
usually when your going 60 in a honda and gas it of course its not going to respond or slow down. its called torque and hondas dont have it, get a v8 or deal with it
Old Sep 25, 2005 | 10:37 PM
byronl's Avatar
really?! it just doesn't feel right to me....o well then
Old Sep 25, 2005 | 10:41 PM
Kyles ej1's Avatar
Default Re: (byronl)
well does it bog or anything? if not then having a honda is your problem, try downshifting next time if you wanna go faster
Old Sep 25, 2005 | 10:44 PM
ClubDownforce's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, i've been having this problem where I'm cruising at 60mph and when I add more gas the car doesn't seem to respond, it just stays at 60mph doesn't go any faster or doesn't slow down. When I add even more gas nothing will happen until I get to a point when I press on the gas down enough that the car will suddenly accelerate. I can really feel it whenever I'm driving on to the freeway onramp or when i'm driving uphills. </TD></TR></TABLE>
VTEC is key for getting up hills.
.Steve's Avatar
You have a lightened flywheel?
BTW, honda=not much torque...
Old Sep 25, 2005 | 10:47 PM
byronl's Avatar
Default Re: (Kyles ej1)
well the car has trouble starting up when cold and I can smell fuel at cold, it doesn't feel right because I've never felt it like this bad before. I can feel it when i'm on the highway too.
Old Sep 25, 2005 | 11:27 PM
ITR97-143's Avatar
check your Timing prob off 2-3 teeth
Old Sep 25, 2005 | 11:41 PM
civic_driver's Avatar
probably a gas leak.. check the fuel pressure and check for leaks
Old Sep 26, 2005 | 12:22 AM
hushypushy's Avatar
you gotta downshift
cdero
Jan 16, 2014 03:45 PM
Hanmin
Jan 6, 2008 01:01 PM
Lostmind004
Nov 12, 2005 01:51 PM
fab
Sep 16, 2004 12:27 PM
