NEED HELP ASAP WITH CAR I DONT KNOW WHATS WRONG!!!
Old Sep 25, 2005 | 10:06 PM
jdmcivic1999's Avatar
Default NEED HELP ASAP WITH CAR I DONT KNOW WHATS WRONG!!!
ok so i was out driving today and my car was running perfect, but than i came to a stop light and when i came to a complete stop, my car started to bog. i dont know how to explain it but my car all the sudden starts to sound like a harley. i pulled over and popped my hood, all the spark plugs where in and tight, so i checked them all looked fine but one had a little oil or something in it, i wasnt sure what though. so i got back in my car and started it and it still sounded like a harley bike. when i started to drive again my car started to spudder i guess you would say whenever i stepped on the gas. so when i finally got home i looked under the car and notice i had an exhaust leak. but i dont think that would have anything to do with the car spuddering when i would step on the gas. you guys have any idea what the problem could be? the oil or whatever it was, was found in spark plug 1.
here is whats done to the motor
-stock 96ls motor-50kmiles
-stock 95ls tranny
-tsudo exhaust
car is converted to OBD1 with no check engine lights
Old Sep 25, 2005 | 10:17 PM
Dohcvt3c's Avatar
Something like this happened to my friend in his stock civic....idk he replaced all 4 spark plugs and it fixed everything...hope it works
Old Sep 26, 2005 | 09:56 AM
Default Re: (Dohcvt3c)
anyone help me please
Old Sep 26, 2005 | 10:00 AM
hoffman4684's Avatar
Check the gap on your plugs.
Old Sep 26, 2005 | 10:07 AM
Project_DX's Avatar
Default Re: (jdmcivic1999)
this is what i would do
1. fix that danm exhaust leak, cause those are just
2. change your fuel and air filters, that may be whats causing the spuddering
3. change spark plugs
also let use know what kind of car it is with what kind of engine
Old Sep 26, 2005 | 10:09 AM
Project_DX's Avatar
Default Re: (Project_DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoffman4684 &raquo;</TD></TR><TR><TD CLASS="quote">Check the gap on your plugs.</TD></TR></TABLE>
also what he said, make sure you get the right plugs with the right gap...they should be NGKs
Old Sep 26, 2005 | 10:16 AM
suspendedHatch's Avatar
Do 3 before 2.
Is there a severe loss of power? If it's missing on one cylinder, you can determine which one by pulling each spark plug wire off individually while the car's running.
Look at the engine in a dark garage and see if you have any sparks jumping from the wires. Take off your distributer cap and just look for anything strange. I had the little screw fall out of the rotor on me before.
Old Sep 27, 2005 | 09:27 AM
Default Re: (suspendedHatch)
still need help
Old Sep 27, 2005 | 01:22 PM
dsowers19's Avatar
Have you replaced the fuel filter before? May need a new one. Also, check the distributor cap and rotor... might be losing power from there.
Old Sep 27, 2005 | 09:08 PM
Default Re: (dsowers19)
ok i replace the fuel filter and the spark plugs, but it still spudders when i step on the gas? it really sounds like a harley when i step on the gas, it spudders like hell. when i drove it, it seems like i lose power because of the spuddering? I dont know whats going on with the motor. BTW im not throwing any check engine lights.
Old Sep 27, 2005 | 09:18 PM
FULLY_BUILT_NA's Avatar
your distributor
jxhxb
May 30, 2008 09:43 PM
lude12423
Mar 27, 2005 07:45 AM
Dc2 Powered
Nov 22, 2004 12:18 PM
Reason
Nov 7, 2004 08:44 PM
Eurorider1
Oct 12, 2003 06:30 PM
