B20/VTEC or LS/VTEC????
Old Sep 25, 2005 | 09:17 PM
92integraVTECgsr's Avatar
Default B20/VTEC or LS/VTEC????
which is better, easier, cheaper to build up?
what are some HP & TQ numbers from those of you who have built these motors.
Thanks.
Old Sep 25, 2005 | 09:29 PM
RudeBwaiSi's Avatar
LSV is less hassling, one reason is that it can utilize a wide variety of OEM pistons, unlike the B20.
Old Sep 25, 2005 | 09:36 PM
highrevnef's Avatar
Default Re: (RudeBwaiSi)
both are really powereful setups. u will get more power off the b20 but the cylinder walls are thin but if u only rev up to 7.5 or les u should be fine. but i dont recomend reving over anything higher from where ur making power. if u do any of these setups tune it cause tunning is the key to any set up. if tuned right ur motor can last as long as any b series. good luck with ur set up.
Old Sep 25, 2005 | 10:35 PM
Default Re: B20/VTEC or LS/VTEC???? (92integraVTECgsr)
ya i plan on spending a good amount of time and money in tuning.. i want it to be tuned 100% the best possible way.
that was my thought about the b20. parts are harder.. the LS can use most b series parts.
barnie
Jan 12, 2009 12:50 PM
JDMeman
Apr 18, 2008 07:46 AM
VTECdohcter
13
Aug 5, 2007 09:52 AM
VolkswagenWHO!!!
Feb 13, 2007 06:55 AM
QuarterMileMaster
23
Apr 26, 2005 04:25 PM
