tranny play?? is this normal what are some tranny inspection methods???
Old Sep 25, 2005 | 08:17 PM
rocketfuelcerx's Avatar
Default tranny play?? is this normal what are some tranny inspection methods???
o.k with the tranny off the engine, the shaft, when turning it clockwise then counter clockwise, you can hear/feel play in between the gears, but everything shifts ok, should i install this tranny this way cause my current LS one knocks (bad bearings)...
Old Sep 26, 2005 | 07:36 PM
Default Re: tranny play?? is this normal what are some tranny inspection methods??? (rocketfuelcerx)
bumpity bump
Old Sep 28, 2005 | 06:09 PM
Old Sep 28, 2005 | 06:51 PM
Muckman's Avatar
Moderator in Chief
Look in the helms. Theres specs for all that.
Old Sep 29, 2005 | 06:51 AM
mmuller's Avatar
Mad Scientist
Default Re: tranny play?? is this normal what are some tranny inspection methods??? (Muckman)
you mean you can hear play when you move the input shaft back and forth? thats normal
Old Sep 29, 2005 | 09:16 AM
Honda Bull's Avatar
Default Re: tranny play?? is this normal what are some tranny inspection methods??? (mmuller)
You should be able to spin the input shaft back and forth maybe 1/8th of an inch at max. What you feel is normal. Now... if it's side-to-side movement then you might be fooked.
Old Oct 3, 2005 | 06:44 PM
tank you...tank you very much....
stRtypR25
Dec 20, 2002 01:35 PM
Dee
Apr 15, 2002 08:22 PM
