Crx restoration project Updae
I finally finished kiling 99% of the rust on the drivers side, After using a wire wheel to clean it up I applied some naval jelly to the rusted areas, then took the my mig welder and beefed up the areas that were getting thin, weak, or small holes, Unfortunately i didnt take as many picture this time.
The rear Jack point was pretty weak, so I spent most of my time working on this
I used new metal, that was about 2 times as thick, im only Using the thick metal for anything structural, and im very lucky that i dont need to use alot.
[/img]
[/img]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">my god those welds look horrible</TD></TR></TABLE>
And ? You grind down welds anyways when doing body work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UsDm_Junky »</TD></TR><TR><TD CLASS="quote">almost as terrible as the girl in your pic</TD></TR></TABLE>
lololol
Keep up the good work..........rust is the devil!
lololol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex »</TD></TR><TR><TD CLASS="quote">
rust is the devil!</TD></TR></TABLE>
no, mama says vicki valencourt is the d.d.devil.
I went through this a few years back, luckily i have family in the business so i got it done cheap
Lol.. I am by no means a welder, Its actually one of my first times welding, and im doing it with little knowlege oher then what i have read.
I did some practice stuff beore to figure the temp settings and what not but i still suck.
just so you know your gonna want to cut all that rust out till there is healthy metal then weld in your patches otherwise sorry to inform you that you will have rust again in your fresh paint job in a couple weeks. IM not talkin **** i just know i have done alot of bodywork
Gotta start somewhere i did the same ****
simpleCRXkid
123
Sep 20, 2010 08:04 PM
01-1293
Oct 10, 2004 09:01 AM
