GSR Interior into EK Civic.
Old Sep 25, 2005 | 07:37 PM
gsrboost's Avatar
Default GSR Interior into EK Civic.
I've been searching and all I could find is that the GSR seats will fit in a ek. What about the dashboard and door pannels from a GSR will they bolt up in a EK?
Old Sep 25, 2005 | 08:36 PM
chinese acrobat's Avatar
Seats will go in if you custom the rails spacing. Dash does bolt in too.
Old Sep 25, 2005 | 08:37 PM
G2 Speed's Avatar
Default Re: (chinese acrobat)
man search harder....!
Old Sep 25, 2005 | 09:21 PM
gsrboost's Avatar
Default Re: (G2 Speed)
if ur not going to help dont bother posting. all i could find was info on swapping a gsr dash into a eg. also i found pics of a gsr dash in a ek but there was no info explaining what was needed to be modified.
Old Sep 25, 2005 | 10:46 PM
liam821's Avatar
25 Year Member
Default Re: (gsrsp33d)
GSR dash doesnt swap into a ek because the width of the dash is a different size. However im sure if you are determined enough you can do anything.
liam
Old Sep 26, 2005 | 07:16 AM
gsrboost's Avatar
Default Re: (liam821)
Someone has done it:
http://www.cardomain.com/ride/555340
Old Sep 26, 2005 | 10:28 AM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrsp33d &raquo;</TD></TR><TR><TD CLASS="quote">Someone has done it:
http://www.cardomain.com/ride/555340</TD></TR></TABLE>
Im not saying its not possible - im just saying its not very easy....
liam
Old Sep 26, 2005 | 10:50 AM
gsrboost's Avatar
yah i hear you. just hoping someone would have some more detailed information on what needs to be modified in order for it to fit.
Old Nov 13, 2005 | 08:58 PM
Dly989's Avatar
give me a few weeks and ill have all the info. for my winterbreak, ill be doing the conversion myself, and ill post a full write up. This is what I DO know about the conversion.
- The dash will need to be cut inorder to fit, as well as custome mounts need being made
- the passenger airbag wont fit because of the support bar across the frame.
- The ENTIRE dash harness needs to be rewired to the specs of the integra (working wiring diagram as we type)
- Inetgra door panels need heated at the bottom to fit properly
- door panels need to be rewired as well
- If your swaping the door panels, you NEED power windows and locks, so be prepared to do that conversion also if your like me and drive a dx civic
thats all I know of right now. but be expecting a full write before christmas. Let me know if you find out more.
c0d0r
Feb 25, 2009 02:20 PM
MarTi E.K
Mar 31, 2008 08:36 PM
blkgsr03
12
Mar 12, 2004 02:41 PM
crazyimport
Aug 19, 2003 11:23 PM
Halo
22
Aug 17, 2003 01:00 AM
