Taking out A/C
Old Sep 25, 2005 | 07:20 PM
1999 Si JEFF's Avatar
Default Taking out A/C
Anyone have a how to perferably with pictures of how to take out the A/C i searched but couldnt find anything i appologize in advance if this already exists
Old Sep 25, 2005 | 07:39 PM
Ricey McRicerton's Avatar
Default Re: Taking out A/C (1999 Si JEFF)
I'll go ahead and advise you not to do it. You're going to regret it.
Old Sep 25, 2005 | 07:41 PM
Heylookits shawn's Avatar
Default Re: Taking out A/C (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I'll go ahead and advise you not to do it. You're going to regret it.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I'll go ahead and advise you not to do it. You're going to regret it.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I'll go ahead and advise you not to do it. You're going to regret it.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I'll go ahead and advise you not to do it. You're going to regret it.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I'll go ahead and advise you not to do it. You're going to regret it.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">I'll go ahead and advise you not to do it. You're going to regret it.</TD></TR></TABLE>
Old Sep 25, 2005 | 07:48 PM
fwdtamiya's Avatar
Default Re: Taking out A/C (Heylookits shawn)
I'm looking for the same, my car came with it removed and i just want to make sure everything is out, i know for sure the blower thing under the passenger side dash isn't out. Also anyone weigh it the whole system when taken out? Or at least the blower?
Edit: And is Heating the same stuff or is that other things also?
Old Sep 25, 2005 | 07:56 PM
trust me ive thought about this for a long time haha thanks for the advice though
Old Sep 25, 2005 | 07:58 PM
Default Re: Taking out A/C (fwdtamiya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fwdtamiya &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking for the same, my car came with it removed and i just want to make sure everything is out, i know for sure the blower thing under the passenger side dash isn't out. Also anyone weigh it the whole system when taken out? Or at least the blower?
Edit: And is Heating the same stuff or is that other things also?</TD></TR></TABLE>
ive heard the a/c takes off about 40 lbs correct me please if im wrong
Old Sep 25, 2005 | 08:01 PM
Luserkid's Avatar
If you take it out get the freon taking out perfessionally so you dont pay the 10,000 dollar fine. Then start taking everything appart. Simple enough huh?
Old Sep 25, 2005 | 08:07 PM
johnnylaw's Avatar
it might take off 40lbs. i dont know what you are driving but i dont think that youd even feel a difference. if weight is that much of a concern then go for it, but if your lookin for reducing the parasitic loss on the engine then IMO, keep it. its not worth it. if you are still concerned with it then take the belt off of it
Old Sep 25, 2005 | 09:40 PM
civic_driver's Avatar
after you remove the freon from the system, it's simple unbolting and removal process
Old Sep 26, 2005 | 02:41 PM
Default Re: (civic_driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver &raquo;</TD></TR><TR><TD CLASS="quote">after you remove the freon from the system, it's simple unbolting and removal process</TD></TR></TABLE>
hey man one question is the a/c belt a separate piece of what? after that i think i know how to take it out
Old Sep 26, 2005 | 04:26 PM
Default Re: (1999 Si JEFF)
and what happens when you take the a/c out does the freon just like spray everywhere or something?
Old Sep 26, 2005 | 04:38 PM
Boosted EM1's Avatar
i took my condensor out and my a/c fan to fit my turbo and everything in there. I might as well take the rest of my **** out too, just wasnt sure what all to take out.
Old Sep 26, 2005 | 04:41 PM
Tundatoe's Avatar
Default Re: (Boosted EM1)
i could never survive without a/c
Old Sep 26, 2005 | 06:28 PM
SE7EN3S's Avatar
Yes and yes. You don't want that **** on you, either!
Old Sep 26, 2005 | 09:21 PM
There are two "nipples" on the A/C lines by the condensor. One is a high pressure and the other one is a low pressure. That's besides the point though. Remove the caps, press a screw driver in the nipples, and the freon will start coming out. It's illegal and unhealthy for the environment. If you decide to go this route though, put a towel on top of the lines so you don't get any of it on you, wear long sleeves, and cover your face or at least your eyes.
The belt is easy. You have to remove the compressor, tensioner and A/C bracket in order to remove the belt, or just cut the damn thing if you feel like it.
Old Sep 26, 2005 | 10:43 PM
ROK801's Avatar
does a write-up exhist?
Old Sep 27, 2005 | 10:49 AM
Default Re: (ROK801)
or pictures of each part to remove...im half way done
Old Sep 27, 2005 | 11:13 AM
thanks for ill the help guys just took it out this afternoon
Old Sep 27, 2005 | 11:53 AM
drktorn's Avatar
a better way is to remove the a/c hose that is attached to the compressor. i think its either a 10 or 12 mm nut. slowly turn it once you hear it releasing just walk away and come back in a bit. i dont recommend it this way either, i would take it to a certified mechanic to get the freon pumped out. much cheaner. if you go with the screwdriver way becareful the freon will give you burn. you will know what i mean. good luck.
Old Sep 27, 2005 | 01:20 PM
Default Re: (drktorn)
need help did it today and now the check engine light is on i took out the condensor and fan and belt what else could have caused it. im thinking maybe electrical
Old Sep 27, 2005 | 07:19 PM
C2daIzZle's Avatar
i never understood why people buy si's then remove all of the features that make them si's?
Old Sep 27, 2005 | 07:35 PM
Default Re: (C2daIzZle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C2daIzZle &raquo;</TD></TR><TR><TD CLASS="quote">i never understood why people buy si's then remove all of the features that make them si's?</TD></TR></TABLE>
umm...AC makes an Si, an Si?
Old Sep 27, 2005 | 07:53 PM
fwdtamiya's Avatar
and all this time i thought is was the MaD TyTe DoHc VtAk
Old Sep 27, 2005 | 09:07 PM
Default Re: (fwdtamiya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fwdtamiya &raquo;</TD></TR><TR><TD CLASS="quote"> and all this time i thought is was the MaD TyTe DoHc VtAk</TD></TR></TABLE>
nahh...it's definitaly gotta be the ice cold A/C
Old Sep 27, 2005 | 10:17 PM
Damon B.'s Avatar
cause At 17 years old, the si was perfect for me, didn't have to do **** but bolt-ons and lower it. At 22, with a g35 to drive daily, the Si is just a toy that I can play with whenever I feel like it. turboed b16, jdm type R, all motor build up. Whatever I want, whenever I want. Haven't even driven the car for a year, and planned on selling it. Now it's just something to play with, ac...gone....cruise...gone...everything behind the front seats...gone. Why buy a cx hatch and turn it into something that makes it not a cx hatch anymore? (maybe it was a bad example, but the same **** really)
