Want to go to bypass valve instead of blowoff valve
Old Sep 25, 2005 | 06:27 PM
elpiar's Avatar
Default Want to go to bypass valve instead of blowoff valve
Anyone got an idea how to modify the intake pipe so I can recirculate to the intake before turbo compressor? I'm thinking of putting like a 2" hole on the bottom face of my cone intake filter and put a short pipe to plumb there.
Help me with ideas. I don't have a welder at home so get me something DIY
If anyone is wondering why, I just like a sleeper style boosted car. My BOV sounds annoying after a while and I like the high pitch spooling sound better than the whoosh...
Old Sep 27, 2005 | 08:54 AM
elpiar's Avatar
Default Re: Want to go to bypass valve instead of blowoff valve (elpiar)
Still need help
Old Sep 27, 2005 | 09:01 AM
nfn15037's Avatar
Just weld on the appropriate sized piece of pipe onto the intake pipe. Then run the rubber hose from the BOV to the 'nipple' you welded on.
redzcstandardhatch's Avatar
something different
sounds like you need to be a bit more creative. if it takes welding, have somebody weld a pipe up. shops weld things for cheap, its not gonna cost 1,000 bucks.
you could make the pipe up (old clean up exhaust pipe works well, and lots of people have it sitting around )
make it, cut it where it needs to be cut, mark it how it needs to go, then take it to a welder. or just get a bunch of silicone or rubber adaptors and clamps and just piece it together.
you could JB weld a return piece onto your intake pipe, or whatever. if its steel or aluminum, you'd be best to have somebody weld it. lots of exhaust shops will do a bit of side-welding on steel stuff.
just be a little creative. it'll get you places fast.
Old Sep 27, 2005 | 01:38 PM
elpiar's Avatar
Default Re: Want to go to bypass valve instead of blowoff valve (nfn15037)
ok thanks guys!
ezza
Feb 7, 2010 09:07 AM
hondalover69
Engine Management and Tuning
Aug 9, 2009 05:26 PM
the.hamburglar
May 26, 2005 06:43 PM
Fatty_1775
Jul 27, 2003 10:30 PM
Flamenco-T
Nov 18, 2001 01:17 PM
