Clutch Chatter??
Old Mar 1, 2002 | 06:24 PM
R-1303's Avatar
Default Clutch Chatter??
Setup is a clutcmaster pressure plate stage 3 and clutch net stage 2 disc...the problem i have is when starting off in first gear after engaging i hear a sqeaking noise..is this chatter or normal for aftermarket clutch??
replaced all bearings and re-surfaced flywheel.
Old Mar 1, 2002 | 06:41 PM
ALF's Avatar
ALF
Default Re: Clutch Chatter?? (R-1303)
Squeaking? It sounds like you didn't lube up your bearings.
Old Mar 1, 2002 | 11:25 PM
R-1303's Avatar
Default Re: Clutch Chatter?? (Dozed)
a friend told me it's becuase the disc is ceramic thats y it sqeaks...could it be something else?!?! suspension or axles??
Old Mar 2, 2002 | 12:20 AM
mingchi96
Guest
Posts: n/a
chatter is when the whole car kinda shakes a lil when its engaging into gear. The squeak you hear is most likely your throwout bearing. Did you replace that.
Hey Dozed.. wat are you suppose to lube up?? wat bearings?? In all the clutch install I have done, I dont lube up anything, maybe exxecpt the pilot bearing.
Old Mar 2, 2002 | 12:27 AM
R-1303's Avatar
Default Re: Clutch Chatter?? (mingchi96)
replaced all bearings..yeah pilot and throwout...and lubed pilot..but i don't know why it sqeaks in first gear engagement???
vtecaccordf22b1
Dec 2, 2007 04:18 PM
poormans_typer69
Oct 23, 2007 07:35 AM
accordinated
Sep 3, 2004 01:32 PM
ludelvr
Sep 28, 2003 11:02 AM
integRated109
Jul 4, 2002 01:53 PM
