blox turbo cams
ive searched but am unable to find any posts with someone who has experience with these cams against other cams commonly used in turbo setups....any info dyno charts etc would be great
I did install them into a Turbo setup I made this winter,
the car did push more hp for shure, we did feel the change pretty bad if you ask me.
however, they killed the low end, we didn't care too much since the car is running a 60-1 at 10 psi, and we didn't expect it to pull anyhow before the turbo is spooled.
Sorry no dyno graph cause we are too far from a dyno here,
they feel good though !
it was on a b16 with 9:1 comp / benson block.
hope this help
kranked.
hope this help
kranked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kranked91dx »</TD></TR><TR><TD CLASS="quote">I did install them into a Turbo setup I made this winter,
hope this help
kranked.
I think you have a tuning/setup issue then, because all anyone has said is the turbo cams knock off a good bit of top end but boost up the low/mid range power.
hope this help
kranked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">We would really need the cam specs to see if these cams were any good.</TD></TR></TABLE>
The specs for the turbo cams is: INT .385” / 230º EXH .350” / 225º
blox says they are high lift...far from it....
93 VTEC
Jan 24, 2003 07:11 AM
DRAGLS
Nov 24, 2001 06:35 PM
