Car now slow?
Old Sep 25, 2005 | 04:59 PM
Babakarab's Avatar
Default Car now slow?
I just changed my oil two weeks ago to mobil 1 from regular oil. I bought the car a month ago with 65k miles. now the car threw a check engine light and the car feels slower. When i checked the dipstick it is a quarter inch higher than the top dot. Does anyone know what is goin on? I think that the oil level is too high and going into the heads. Please help i dont wanna blow my motor. I already did searches but couldn't real find anything definitive.
.brian.'s Avatar
Default Re: Car now slow? (Babakarab)
how much oil did you put in?
Old Sep 25, 2005 | 05:00 PM
Babakarab's Avatar
It might have like 4.2 in. I took it to a ford dealership i work at.
Old Sep 25, 2005 | 05:08 PM
KeithsDAteg's Avatar
Exactly what Kind of Car is it??
and do you know what code it is throwing?
Old Sep 25, 2005 | 05:25 PM
Babakarab's Avatar
Default Re: Car now slow? (KeithsDAteg)
It threw a code today and i haven't had the chance to find out. It is a 98 gsr dc2 and the car feels slower than normal once it hits vtec. It takes about twice as long to go from 6k to 8k rpm.
Old Sep 25, 2005 | 05:30 PM
.brian.'s Avatar
https://honda-tech.com/zerothread?id=978933
hopefully that helps with the code
Old Sep 25, 2005 | 05:42 PM
If I had to guess, I would say that you arent Actually "hitting Vtec".
The first thing you need to do is Get the oil level to normal, then Reset the Ecu.
To reset the ecu, pull the 7.5amp "Backup" fuse under the hood and wait for About 30sec.
Once you do all of that, Find out what code you are throwing. You work at a Ford Dealership, you should be able to get your hands on a Generic ObdII Scanner.
Old Sep 25, 2005 | 08:02 PM
Babakarab's Avatar
thanks for the responses. I'm going to go check what code it is. Could i do serious damage by driving with too much oil in my car. There is no dash or mark on my dipstick but it is a little higher than the second dash when the oil is cold.
Old Sep 26, 2005 | 01:05 AM
You need the get the oil Level no higher then the Top mark on your dipstick, but no lower than the lowest mark.
Old Sep 26, 2005 | 11:32 AM
.brian.'s Avatar
bump
Old Sep 26, 2005 | 01:41 PM
95lstegman's Avatar
Default Re: Car now slow? (.brian.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Babakarab &raquo;</TD></TR><TR><TD CLASS="quote">Could i do serious damage by driving with too much oil in my car.</TD></TR></TABLE>
YES! by revving high. keep the revs low until you fix the problem. just let some oil out then check and fill to proper level. the damage you cause would be very expensive to fix, requiring a lot of labor. it would burn oil until you had the motor (or just the head) rebuilt.
Juzjoshnu
Mar 12, 2018 02:21 PM
sydag5
Acura TSX
Mar 5, 2016 12:47 PM
jrea2008
May 9, 2007 02:56 PM
SlippylesKB
Nov 12, 2003 07:21 AM
DuNkiN
Sep 30, 2002 08:26 PM
