crx cv axel prblems
Old Sep 25, 2005 | 04:39 PM
I_eat_Rice's Avatar
Default crx cv axel prblems
Every body has told me an axel job should take about an hour maybe less, unless that is there are complications. well there are complications. Everything was going fine untill we tried to get te axel but off. Ive used a 260 pound impact wrench and broke a 1/2 inch ratchet with a 4 foot cheater bar, also used a breaker bar and it still wont budge. got any ideas?
Modified by I_eat_Rice at 5:56 PM 9/25/2005
Old Sep 25, 2005 | 05:10 PM
Crx Jimmy's Avatar
Default Re: crx cv axel prblems (I_eat_Rice)
use a 500lb air gun, or try a 6 ft pipe
Old Sep 25, 2005 | 05:15 PM
Crx Jimmy's Avatar
Default Re: crx cv axel prblems (Crx Jimmy)
also make sure you are loosening the nut when the car has its wheels on and is on the ground otherwise the impact gun wont be impacting as hard
Old Sep 25, 2005 | 05:47 PM
ghost_ryder35's Avatar
spray a whole **** load of PB on it and some WD-40 maybe while your at it... and this is what I had to do, use a torch and throw some heat on that bitch till she turns red. then wait till it cools a little bit so its not red and crank on it. they are always BITCHES
Old Sep 25, 2005 | 07:47 PM
redryder's Avatar
do this it worked for me. Drive around the neighborhood for about 20 or 30 minutes on the brakes doubly hard. go home and use a breaker bar. The nut will pop off real easy from the heat you produced from the brakes. it'll work I promise. I did it twice for both sides of my civic.
Old Sep 25, 2005 | 10:21 PM
RCautoworks's Avatar
Default Re: crx cv axel prblems (redryder)
My little story
Used a 600lb impact gun, that did not budge it. Used a 6ft extension on a pry bar with a 2 inch ratchet, thats right 2 inches.
The pry bar used to jam the wheel so it would not turn. Keep in mind, this was straight before it was used
The breaker bar and ratchet, these are not your little every day ratchet, the axle nut is in the middle, to give you an idea of how big those really are.
The axle nuts
Old Sep 26, 2005 | 04:48 PM
I_eat_Rice's Avatar
Default Re: crx cv axel prblems (90blackcrx)
ok I was talking to somebody and the idea that the lugs might be reverse threaded, are they. Im just wanting to make sure that im not spinning the tires on the ground in the wrong way just tightening them.
Old Sep 26, 2005 | 05:06 PM
kulangot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I_eat_Rice &raquo;</TD></TR><TR><TD CLASS="quote">ok I was talking to somebody and the idea that the lugs might be reverse threaded, are they. Im just wanting to make sure that im not spinning the tires on the ground in the wrong way just tightening them. </TD></TR></TABLE>
someone lied to you.....
natemoore
22
Jul 21, 2014 03:01 PM
xSCTYGx
Jun 2, 2004 09:21 PM
raceACCORDingly
Apr 3, 2004 01:38 PM
FUP23
31
Aug 2, 2002 12:20 PM
TurBoXBirD16
11
Jun 19, 2002 06:35 PM
