Radio Noise after going aftermarket help! 5th generation
Old Sep 25, 2005 | 02:53 PM
Hondapreludeg's Avatar
Default Radio Noise after going aftermarket help! 5th generation
I have a 1997 prelude that had a stock cd player in it with the acoustic feedback system. I put an aftermarket alpine unit in now i have a whinning noise coming through the speakers the faster i go so does the noise. I even changed the ground and i still have the problem. ANy suggestions thanks!
Old Sep 25, 2005 | 09:26 PM
l2yanE's Avatar
did u dissable the acoustic feedback? the rear speakers are only 2 ohm they dont work right with a new HU, or are u runnin subs? if thats the case move the RCA's away from ur power source-
Old Sep 26, 2005 | 05:36 AM
integra15's Avatar
Default Re: (l2yanE)
Do you have an amp? I would check the wire harness make sure the connections are very good. You really should not have any noise in the system, espically if all you did was add a new head unit.
Old Sep 26, 2005 | 05:58 AM
ny_blue_01's Avatar
Default Re: Radio Noise after going aftermarket help! 5th generation (Hondapreludeg)
No harm in checking the harness connections and use butt connectors to secure the wires.
Alpine HUs use alot of current so make sure that your grounds have good connections. Upgrade to a larger power wire from the battery, Upgrade Ground Wires from battery to the car frame. Ground the HU directly to the frame and keep power ground wires away from speaker rca's and wire connections. If whining persists then you may have to just deal with it or get a bigger alternator.
I still get whining noises when I have the AC on, but I do have a full system - 2 amps, subs, component speakers.
Old Sep 26, 2005 | 11:17 AM
maks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l2yanE &raquo;</TD></TR><TR><TD CLASS="quote">did u dissable the acoustic feedback? the rear speakers are only 2 ohm they dont work right with a new HU, or are u runnin subs? if thats the case move the RCA's away from ur power source-</TD></TR></TABLE>
It seems like you still have the acoustic feedback running. I installed a new Panasonic deck recently, and bypassed the feedback system (box in your trunk). It works like a charm, sound is way better than before. Rear speakers definitely work right with my new HU.
Old Sep 26, 2005 | 09:14 PM
Have 12' kicker sub and 600.1 amp and all the stock speakers had the sound before the amp and sub install.. i tried moving the wires away from eachother didnt help is worse with A/C on also should i disable the acoustic feedback and how do i do that?
Thanks J
Old Sep 27, 2005 | 10:48 AM
maks's Avatar
Default Re: (Hondapreludeg)
Yes, get rid of the acoustic feedback system, it's a small box that sits between your rear speakers in the trunk...
Originally, wires go like this: Head unit, to acoustic feedback system, to rear speakers.
What you want is for them to go: Head unit to rear speakers.
abusedvtec
May 4, 2008 09:56 AM
JDMlyfestyle
12
Dec 10, 2004 04:24 PM
EKtypeRhaTcH
Audio / Security / Video
Dec 12, 2003 10:22 AM
tvrsir
Nov 18, 2003 05:02 PM
IntEgRaxbOyx415
Jul 6, 2002 03:09 PM
