EG6 GSR gas 87, 89, 91?!?!
Im getting my EG6 GSR swap done. I would like to know which gas i should be using, and if i use a lower grade will it corrode or slowly damage the engine?because the stock D15b non-vtec i had on there i used 87. Appreciate everyones input...thanks!
-95 cx GSR
-95 cx GSR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V8-eater »</TD></TR><TR><TD CLASS="quote">Im getting my EG6 GSR swap done. I would like to know which gas i should be using, and if i use a lower grade will it corrode or slowly damage the engine?because the stock D15b non-vtec i had on there i used 87. Appreciate everyones input...thanks!
-95 cx GSR</TD></TR></TABLE>
gsr use 91 premium only. don't go by your old motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX »</TD></TR><TR><TD CLASS="quote">use whatevers the best you can get. i use 93 but i think thats an east coast thing</TD></TR></TABLE>
im in texas and thats all i can find is 93
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aandrewcc »</TD></TR><TR><TD CLASS="quote">if i put 89 would that still be alright ?? </TD></TR></TABLE>
No.. Those engines require 91+ octane. If you dont want to pay the 7 extra cents per gallon of gas then dont do the freaking swap. Do it right or not at all.
yea, unless it starts knocking
but if the manual says 91 put that in, don't go any higher because you won't see any difference except.. less money in the bank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 »</TD></TR><TR><TD CLASS="quote">
No.. Those engines require 91+ octane. If you dont want to pay the 7 extra cents per gallon of gas then dont do the freaking swap. Do it right or not at all.</TD></TR></TABLE>
x2. It's not even a huge price difference. Its a freaking Civic gas tank (average 10 gallon tank) so you save. $ .70 cents.
Oh Sohc Slow
33
Jan 4, 2004 07:52 PM
Oh Sohc Slow
12
Jan 1, 2004 10:46 PM
