F20C in CRX FWD/RWD Question
Old Sep 25, 2005 | 01:23 PM
94prelude1488's Avatar
Default F20C in CRX FWD/RWD Question
If I do decide to go with an F20C Engine and transmission what would i need to do to make the CRX run as a FWD, if this is possible? OR If i were to go with the F20C engine and the JDM K20A Transmission would it run as a FWD car, and if not how could I make it? Any help would be appreciated, thanks.
Old Sep 25, 2005 | 01:34 PM
Suck my DX's Avatar
Default Re: F20C in CRX FWD/RWD Question (94prelude1488)
worst question ever
Old Sep 25, 2005 | 01:43 PM
Jesterian's Avatar
24.243.141.75
Default Re: F20C in CRX FWD/RWD Question (Suck my DX)
What would you need to do to convert your CRX to run as a FWD car? Man, the infamous FWD to FWD conversion is mostly custom work, I doubt you have the money for it.
Old Sep 25, 2005 | 02:14 PM
MtnCRX's Avatar
you make me laugh
Old Sep 25, 2005 | 03:08 PM
EFOSV's Avatar
you make absolutely , no sense ....
Old Sep 25, 2005 | 03:10 PM
The DX Rex's Avatar
Default Re: (EFOSV)
that is funny, but i read somewhere the k series tranny bolts to the F20C motor, that doesnt mean it will work but let us know how it turns out
Old Sep 25, 2005 | 03:28 PM
.Grimace's Avatar
footwork mastery
Default Re: (The HF Rex)
this kid is crazy. fwd conversion on a crx. wow man post some pics of this project for us
Old Sep 25, 2005 | 03:31 PM
what i meant is if i used the f20c tranny, which is rwd, would it work on a crx chasis as a fwd or rwd?
Old Sep 25, 2005 | 03:33 PM
SiR Inspired ED7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94prelude1488 &raquo;</TD></TR><TR><TD CLASS="quote">what i meant is if i used the f20c tranny, which is rwd, would it work on a crx chasis as a fwd or rwd?</TD></TR></TABLE>
lol, are you serious?
Old Sep 25, 2005 | 03:49 PM
turbotommy's Avatar
Default Re: F20C in CRX FWD/RWD Question (88 Crx Si)
the f20c motor and drivetrain would most likely be fabbed into a crx in a rwd configuration. this is because in a rwd car the only thing connecting the transmission and the two axles is a driveshaft. IF you tried to make it fwd what would you do? there would only be a driveshaft so it would probally never work in a fwd application. now IF the k series tranny bolts up to the f20c it is very possible the motor and k-drivetrain could be fabbed in a crx in a fwd application. you would have the driveshaft, differential, axles all in one package. WAY easier to fab..
hope this helps...
Old Sep 25, 2005 | 03:52 PM
Default Re: F20C in CRX FWD/RWD Question (turbotommy)
thats what i was looking for. thanks for the help.
Old Sep 25, 2005 | 04:02 PM
i found the info on a different forum
"yes im sorry this is what i meant i was looking into doing this swap previously and the k20 tranny will bolt up to it and it does make the car front wheel drive, u do also need the intire suspension as well to make it possible" (talking about bolting to an F20C)
"the K series tranny bolts right up to the F20C, so you can make it FWD."
as far as i'm understanding i can bolt a k20 tranny to an f20c engine and it will run as a fwd...if ne1 has info on bolting the k20tranny to an f20c engine it'd b appreciated
Old Sep 26, 2005 | 06:42 PM
turbotommy's Avatar
what info would u be looking for?
it would assume it would be no different than bolting a b16 tranny to a b20.
Old Sep 26, 2005 | 07:01 PM
luvda'boost's Avatar
Go easy on the guy, he's only 17.
I'm guessing you want to stuff the "best" motor available into a CRX. Why not go with something that has been done about 20 dozen times or so and it's had all the guess work removed?
From your question I am also guessing that you didn't grow up in a garage or fab shop. Not ******* you just a gentle suggestion to take the road that is well traveled until you can use a mig, lathe and metal break.
Old Sep 26, 2005 | 07:07 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: F20C in CRX FWD/RWD Question (luvda'boost)
I quit not drinking
Old Nov 29, 2019 | 07:40 AM
W90crzsi's Avatar
https://engineswapdepot.com/?p=38987
old tread I ran up on sorry
Old Dec 25, 2019 | 10:07 AM
Cody Manz's Avatar
hope this helps...
Nice to see someone actually helping. Sucks seeing all these ****** that pick apart how he worded the question.
kojack_0
Feb 29, 2008 02:37 AM
CRXdaBEAST
Feb 12, 2008 06:46 PM
YashiMotors
41
Sep 26, 2005 06:40 AM
jedubz
Dec 20, 2003 02:32 PM
insomniac791
Jun 22, 2003 10:35 PM
