B-SERIES TURBO KIT:
Stage 2C 92-95 Honda Civic Turbo Kit
Application: 92-95 Honda Civic with Hybrid B-Series B16 B18 B20 Engine
The 92-95 Honda Civic is one of the easiest vehicles to add horsepower to. Our 92-95 Honda Civic turbo kit offers reliability for street use that Rev Hard is known for. The horsepower offered by our 92-95 Honda Civic turbo kit also makes it great for track use. Horsepower gains are usually in the 120hp range and gains for torque are about 285 ft/lbs. The 92-95 Honda Civic kit can be used with stock injectors for a 7psi level of boost.
92-95 Honda Civic Turbo Kit consists of the following components:
-- Rev Hard Cast Iron Manifold
-- Rev Hard T3/T04E Hybrid Turbo(eff. to 450hp)
-- Rev Hard Intercooler (27" x 6.5" x 3")
-- 38mm External Tial Wastegate(7psi)
-- Vortech Blow-Off Valve
-- 2.25" Aluminized Mandrel Bent Piping
-- 2.5" Downpipe w/ Testpipe Attatched (all ready for bolt up exhaust)
-- Boost dependant fuel regulator
-- Check Valves
-- Silicone Couplers and Clamps
-- Silicone vacuum line
-- High pressure fuel line
-- Steel braided -3 Oil feed line
-- Oil Return Line
-- Necessary Vacuum Lines
-- Necessary Vacuum Tee's
-- Necessary bolts and fasteners
email me if your interested... ericmorris@SirromMotorsports.com
This is a semi used kit thats seen maybe 2-3000 miles tops of actual usage. Pictures apon emailed request.
-- Check Valves
-- Oil Return Line
bump because i have an interested friend, will show him as soon as i get to work
Please email pics to LUGmyNUTS@aol.com
http://www.sirrommotorsports.c...umb=1
(note: I have tape over all the inlet/outlet holes so that no dibree can get in there while the kit has been sitting.)
def looks good to me, and the way you taped it off also shows you care about your things, so i will def try and get my buddy to buy it, i might be contacting to you come look it if that will be at all possible. Where are you located?
Ehhhh dunno where that is exactly, I just moved to WA. I told the guy about it tonight and he is all about buying it, He wont have the $$$ until Friday (Payday) but he will buy it, if it isnt sold buy then. Please keep me updated, this guy needs to be boosted STAT.
*edit* I visited your site, i saw Port Angelas, if that is right you are about 1.5-2 hours from me, i am sure we could meet up with you, he wants me to look the kit over (like i said, seems to me you took good care of it) and he will have cash in hand. This is if you still have the kit.
