92-96 h22 vs 97-01 h22 lost motion assembly?
Is there a difference in the 92-96 h22 lost motion assembly to the the 97-01 I heard there is but I haven't had a chance to crack open a 97-01 head yet to confirm.....
thanks
thanks
Yes, there is a difference. The 92-96 is similar, if not the same, as the Integra LMA, while the 97-01 is the open spring style. I'd have to check part numbers to say the earlier preludes are the same as the integras, but I know they are more expensive, and not the ones people use to upgrade.
Completely different... also the head on the 97+ Preludes is machined different in this area. If you use the 97+ LMAs in an earlier head, you will need to use a .040" shim.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 »</TD></TR><TR><TD CLASS="quote">Completely different... also the head on the 97+ Preludes is machined different in this area. If you use the 97+ LMAs in an earlier head, you will need to use a .040" shim.</TD></TR></TABLE>
Yes there is a differnce. But they are the same for vtec 93-98 99-01 yes 99-01, No I do not know why 97 and 98 have the earlier desing they just do. The 99-01 have diffent part #'s and a totally differnt design hope this helps
Ah, that's right. I couldn't remember what the deal was. I thought that there was some wierdness like that, but I forgot the year split.
It's easy to see the difference:
If you have the valve cover off, just peek under the rockers and take a look, the Prelude LMA is a bare spring, the Integra has a housing around it.
bringing this back from the dead for confirmation,
on a b series head you need to use the 92-96 H22 LMA's which are part number 14820-p73-j01 correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i »</TD></TR><TR><TD CLASS="quote">
nope you need the newer style h22 lma's i beleive PCB's dont forget the .040 hardened washers
or just plain ole ITR or GSR lma, but theyre more expensive</TD></TR></TABLE>
really? i thought it was the p73's bc they look almost identical to b series lma's?
Thanks for the heads up man
call me a noob or w/e but what does an lma actually do? i have heard people swapping them out for other lma's but i dont know why? is there ne advantages?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 »</TD></TR><TR><TD CLASS="quote">
Thanks for the heads up man </TD></TR></TABLE>
actually you're right, either run p73's(p73's are not prelude lma's they are actually typeR lma's) or run pcb's with shims... someone correct me if im wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khrys771 »</TD></TR><TR><TD CLASS="quote">they look nice..... but, can you run those and some skunk2 pro1 cams? </TD></TR></TABLE>
of course
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network »</TD></TR><TR><TD CLASS="quote">call me a noob or w/e but what does an lma actually do? i have heard people swapping them out for other lma's but i dont know why? is there ne advantages?</TD></TR></TABLE>
in lamest terms they prevent the mid vtec rocker from flopping around...
advantages are pre-obd 1 are prone to failure (binding and rocker arm pad issue's) also if you start getting a rondom tick from your vtec head a worn lma is likely the cause, instead of spending $250+ on gsr or itr lma's people use h22 lma with shims (theyre slightly shorter in length) ..
example: i personally run itr lma (same as gsr just different part no) since my head is a 90 B16a head i upgraded for insurance...also because they were already ticking pretty loud..
i actually just installed some h22 lma's with shims in my cousins lsv..waaay cheaper route than the alternative..
Modified by onepoint6i at 3:31 PM 8/21/2007
of course
ahhhh that makes sense. i always thought that the ticking in my motor was because of the large cams i was running and that i needed a valve adjustment when in reality it is my lma's. lol looks like ill be buying some itr lma's now lol
i would still like some sort of proof or something that they wont bind or eat at the lma walls. any post of prelude people running big cams with these?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network »</TD></TR><TR><TD CLASS="quote">does ne one have a link to where i can buy the itr lma's????</TD></TR></TABLE>
acura dealer..
acura dealer..
bahahaha in lamest terms. lol
exposed spring FTW
exposed spring FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">It's easy to see the difference:
If you have the valve cover off, just peek under the rockers and take a look, the Prelude LMA is a bare spring, the Integra has a housing around it.</TD></TR></TABLE>
thanks for the pic , looks like those are the part nuber for my f20b (pcb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khrys771 »</TD></TR><TR><TD CLASS="quote">i would still like some sort of proof or something that they wont bind or eat at the lma walls. any post of prelude people running big cams with these?</TD></TR></TABLE>
PM omni-man
PM omni-man
for anyone that's interested i pm'd "drdisco69" to verify the part number on the H22 LMA's you need for a b-series and he said that it is "14820-PCB-003".
And here's a link to where you can get them at $7.17 a piece http://www.hondaautomotivepart...r+---
