what does it mean when there is a red indictor on the cluster?? green->yellow->red?
is it mantenance(spelling not right)? if so, what needs to be done? 145k on cluster. let me know asap so i can get it fix. thanks.
It just means you're due for your next maint. service- 10k/30k, etc. Just use your key and reset it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal »</TD></TR><TR><TD CLASS="quote">is it mantenance(spelling not right)? if so, what needs to be done? 145k on cluster. let me know asap so i can get it fix. thanks.</TD></TR></TABLE>
You do realize that honda-tech has a spell check?
cool. thanks all. so it does it every 3000 miles? i thought i meant that i need a major tune up or something.
IF IT IS A MAJOR TUNE UP THAT IS NEEDED, WHAT NEEDS TO BE DONE OR CHANGED?
for all of u that helped. AND IS THERE REALLY A SPELL CHECK ON H-T?LOL
Holy crap they do have spell check...
How many miles are on the car? never mind saw it... If you have a helms, doing this stuff will be easier...
If not done recently I would change Spark plugs, air filter, wires (if bad), Dizzy cap and rotor, PCV valve, timing belt, water pump, tensioner.... You don't have to it all at once, buy and change it little by little...
yes it will go to yello at like 2900 and then red at 3K.. this has nothing to do with the motor or sensors all it reads is the O/d if it is some thing with the motor your check engine light will come on bright yellow
JohnnysEG
14
Mar 8, 2004 08:05 PM
