Please help me build my car
I have a 92 accord lx, I want to do an engine swap but im not sure what to go with, im not that familiar with imports so i need some help. whatever i go with i want to beable to build up without going broke. Thanks for your help.
what are you looking for? If you really don't want the engine in your car, I think you could put a H22 in there, but the engine can be as expensive as having a turbo in your car!
If the idea sounds expensive, maybe you should install intake, header, full exhaust, light weight pulleys, stage 2 or 3 clutch, short shift, full suspension upgrade and brake upgrade, cam gear, cam shaft... and then.... ..."should I get a engine swap??"...
If I were you... I would "work" withe the F22!
My next step will be light weight pulleys, including the crank (..no underdrive..), and then... a stage 2 or 3 clutch, with a aluminum flywheel....
Sure I can't compare an accord with a bmw... but.... ...it is faster than a stock accord, and I'm able to keep up with mustangs and trans ams.... (...maybe V6's..)
Nitrous... ...well... I wouldn't do it.... ..I could not trust such thing in my car....
Do a full exhaust, maybe 2.25 pipe or 2.5 pipe.
Have you got an Intake, headers yet?!
Don't forget, if you are hooking up your engine... consider a full suspension upgrade.... like coilovers or springs... and throw some KYB agx in it!!!
right now its a rust bucket with some cheap coilovers and a cracked tranny. It does have a cold air intake though. I have 2 extra trannys and 2 extra motors. ill have the body done in no time but i wanna build the motor this winter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsucci »</TD></TR><TR><TD CLASS="quote">most of the cars around here are going with the b18 swap, id like to go alittle above this, weather it means building my f22 or doing a swap. </TD></TR></TABLE>
Nobody puts a b18 in their accord. Not enough torque. If you are on a budget, turbocharging your F is the way to go.
you should go with a H22 but without da money den u should start Moding your engine now den when you have den money either Option 1.do a engine Swap with the H22 or Option 2.Put on a turbo with stage 2 clutch but in this case i would Mod my engine then turbo it unless you have the money then get the H22 but if not go with option 2 What do you Think?
or
cause im just helping you not chosing for you
or
fallingfrominfinity
Mar 4, 2004 04:04 PM
