Which is the lightest?
Old Sep 25, 2005 | 09:52 AM
r3pp3r's Avatar
Default Which is the lightest?
What is the lightest stock integra/civic wheel, not including type R?
Old Sep 25, 2005 | 09:53 AM
lazie's Avatar
92-95 civic vx wheel 9lbs at 13in
Old Sep 25, 2005 | 09:55 AM
r3pp3r's Avatar
Default Re: (lazie)
How about 14" or bigger only? Although the vx wheels look pretty nice...
Old Sep 25, 2005 | 09:57 AM
lazie's Avatar
Default Re: (r3pp3r)
96-99? civic hx 11lbs at 14in
r3pp3r's Avatar
Default Re: (lazie)
How much do stock integra steelies with hubcaps weigh?
Old Sep 25, 2005 | 10:01 AM
lazie's Avatar
you can find all honda/acura wheels here http://www.fatboyraceworks.com/wheels/
Old Sep 25, 2005 | 10:04 AM
r3pp3r's Avatar
Default Re: (lazie)
Some useful info there, but not what I need. Thanks for your replies. I'm guessing the steelies are ~18 lbs, so once these tires wear out I think I'll be getting some HX rims with acura center caps.
Old Sep 25, 2005 | 10:52 AM
r3pp3r's Avatar
Would shaving ~7 lbs of wheel weight off produce a noticable difference in fuel economy, acceleration, or suspension responsiveness (unsprung weight)?
Old Sep 25, 2005 | 12:21 PM
lazie's Avatar
actually you would be saving 28lbs on all four coners, and yes it would be better for fuel and acceleration but that also depends if your always driving at high rpm's keep it below 3k.
as far a suspension i wouldnt really be sure about that, look in to some new tires, rims, coil over setups and all that go to the suspension forum for that
Old Sep 26, 2005 | 10:21 AM
r3pp3r's Avatar
Default Re: (lazie)
2 more questions. Where do you guys usually get used HX rims, I'm having some trouble finding used ones. The second question is will acura 2.75" center caps fit?
BIG T
May 18, 2009 10:22 AM
b16vtecsol
Dec 16, 2003 12:54 PM
sxecustoms
14
Nov 19, 2003 06:30 PM
TONEBONE
Aug 14, 2002 04:11 PM
EK-Cruiser
Sep 2, 2001 09:00 PM
