FS: D16z6 head sohc vtec w/ bent valve, let it go for cheap
Old Sep 25, 2005 | 09:38 AM
bambam's Avatar
Default FS: D16z6 head sohc vtec w/ bent valve, let it go for cheap
I've got a sohc vtec d16z6 si head that has two bent intake valves on the number 4 cylinder. other than that, head is pristine it has been cleaned and didn't smoke or burn any oil at all. 100 shipped or make an offer.
Old Sep 25, 2005 | 01:04 PM
the jdmchop's Avatar
Default Re: FS: D16z6 head sohc vtec w/ bent valve, let it go for cheap (bambam)
is this a complete head?
manifold , sensors, etc...
just bent valves? hows the guides?
Old Sep 25, 2005 | 04:18 PM
bambam's Avatar
complete with throttle body, injectors, fuel rail and sensors tps is not broke. just the 2 bent valves. compression tested all 4 cylinders on my mini me...
cylinder 1: 225
cyliner 2: 217
cylinder 3: 222
cylinder 4: 0
snapped a rod and piston turned on me and smacked the cylinder 4 intake valves. just once.
let me know if you're interested.
Old Sep 26, 2005 | 03:37 AM
bambam's Avatar
other than that...head is mint and strong...just look at the compression numbers. replace the two valves with one from a spare head and you're good to go.
Old Sep 27, 2005 | 08:00 PM
bambam's Avatar
bump
NAcoupeNA
Jan 27, 2014 05:14 AM
caspers_hatch
May 23, 2007 12:50 PM
Eyal 951
May 19, 2006 08:30 PM
hatch2780
Dec 4, 2005 08:28 PM
