eg6 rear brake line conversion ? >>
Old Sep 25, 2005 | 09:37 AM
platinum00's Avatar
Default eg6 rear brake line conversion ? >>
i have a 2000 civic ex, i just put a set of rear disks on from a EG6.
the brake line fittings are not matching up. im assuming i just need the rear rubber lines from a EG now.
is that correct. if so i will just get some stainless
thanks for the help
platinum.
Old Sep 25, 2005 | 04:53 PM
platinum00's Avatar
Default Re: eg6 rear brake line conversion ? >> (platinum00)
ttt.
someone knows this.
platinum.
Old Sep 26, 2005 | 01:48 AM
BlueIntegraBoy's Avatar
Are you using the brake lines that came with the rear disks?
Old Sep 26, 2005 | 04:52 AM
platinum00's Avatar
Default Re: eg6 rear brake line conversion ? >> (BlueIntegraBoy)
no, im using the originals from the ex drums.
since i dont have the ones that came with the disks. i can just buy any EG rear lines and i should be fine correct ?
thanks for the help
platinum.
Old Sep 26, 2005 | 05:18 AM
nub.96ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">no, im using the originals from the ex drums.
thanks for the help
platinum.</TD></TR></TABLE>
EG raer lines for disc brakes will fit. The fitting ends on the drum lines are different, that's why they won't mach up.
Old Sep 26, 2005 | 05:27 PM
platinum00's Avatar
Default Re: eg6 rear brake line conversion ? >> (nub.96ek)
thanks.
does it have to be and EG rear line, or any rear disk line.
platinum.
Old Sep 26, 2005 | 05:37 PM
pdiggitydogg's Avatar
wow I havent heard anyone say "platinum" for a looong time.
I have a set if you want them...just gotta find them
Old Sep 26, 2005 | 05:40 PM
platinum00's Avatar
Default Re: (pdiggitydogg)
ok man, hook it up..
ill pay for them if needed. i just need to get this thing back on the road before winter.
i dont think its going to happen though, no time
Old Sep 26, 2005 | 05:42 PM
send me a pm to remind me to look tomorrow - ive got a lot going on right now and will forget otherwise
Old Sep 26, 2005 | 05:57 PM
JasonGhostz's Avatar
Default Re: (platinum00)
I have a pair of rubber Raybestos rear brake hoses for a 1999-2000 CIVIC 2DR SI (no ABS). They are Raybestos P/N BH380062 and BH380064. They are both unused, in the box (leftovers from a brake conv). I'll post some pics and look up the compatibility of the EG/EK rear brake lines. I'm thinking you might have trouble if you get an EG set of rear hoses, as they may attach to the brakes lines in a different manner... despite the fact that they have the same caliper attachment. More to come..
JasonGhostz
BlackCivicEX
Suspension & Brakes
Apr 28, 2012 07:10 PM
BlackCivicEX
Apr 28, 2012 04:22 PM
cayman_hatch
Aug 26, 2005 10:58 AM
MisterB
Dec 4, 2002 09:52 PM
