Replacing Heater Core Questions
Old Sep 25, 2005 | 07:40 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Replacing Heater Core Questions
Is there anyway to replace the heater core OTHER than removing the dash?
What tools are needed?
If I keep the car, I might just try to hack up the dash, so I won't have to go through all the work
thanks
Old Sep 25, 2005 | 07:50 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: Replacing Heater Core Questions (MugenHonda)
No sir. Dash must be removed.
Old Sep 25, 2005 | 07:52 AM
EG93si's Avatar
i just replaced mine, took like 4 hours, prob do it in 2 now that i know what im doing but you NEED to take off the dash, cluster, drop the steering colum, and steering wheel support, and pry the heater off of the rest of the unit, im not going to lie, its a bitch
ive got pictures if you need them, what kinda civ is it? mines a 93si
Old Sep 25, 2005 | 07:53 AM
EG93si's Avatar
Default Re: Replacing Heater Core Questions (EG93si)
couple screw drivers, basic socket set, time
Old Sep 25, 2005 | 07:58 AM
litterbox's Avatar
This thread will most probablyhelp
https://honda-tech.com/zerothread?id=1211255
Old Sep 25, 2005 | 08:28 AM
MugenHonda's Avatar
ANy DIY faq's
And where did you guy's get your heater core.
Can you test a junkyard one to see if it works or is it a gamble and how much does a new one cost.
What are the symptoms of a bad heater core?
I have no heat, can that be one?
I assumed it is.
The only code I have is code 41
Old Sep 25, 2005 | 08:32 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">
They usually leak.
Old Sep 25, 2005 | 09:12 AM
MugenHonda's Avatar
Default Re: Replacing Heater Core Questions (Chiovnidca)
forgot about that.
Yeah mine doesn't leak, but it is very bothersome that I have no heat, especially when it gets cold and i need it as a defroster
Old Sep 25, 2005 | 09:30 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">forgot about that.
Yeah mine doesn't leak, but it is very bothersome that I have no heat, especially when it gets cold and i need it as a defroster</TD></TR></TABLE>
Hows your coolant level? T-stat working properly? Is the hot water valve opening? How about the heater controls?
Old Sep 25, 2005 | 01:26 PM
MugenHonda's Avatar
i don't know what to check on the hot water valve
but t stat and coolant is fine
no leaks
Old Sep 25, 2005 | 02:08 PM
MugenHonda's Avatar
Fixed
it was that valve that connects to the heater core.
The valve which should be connected to that wire was loose and it was stuck in the heat position
Old Sep 25, 2005 | 03:27 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">Fixed
The valve which should be connected to that wire was loose and it was stuck in the heat position</TD></TR></TABLE>
That was alot easier than replacing a heater core.
Old Sep 25, 2005 | 03:37 PM
MugenHonda's Avatar
i mean stuck in the cool position
when the heat is on, it is suppose to be in the same direction the hose is, when the cool is on, it is perpendicular to the hose
yOnKiNaToR
Jul 17, 2007 04:12 PM
paulzy
Feb 3, 2003 04:47 PM
Brewer
13
Oct 7, 2002 06:10 PM
Coaster
Nov 30, 2001 11:53 PM
