B20vtec Swap, no throttle?!?!? HELP!!!
Old Sep 25, 2005 | 04:36 AM
SpoonEk253's Avatar
Default B20vtec Swap, no throttle?!?!? HELP!!!
hey you guys i've just recently drop a b20vtec into my 96 hatch and everything runs fine except that when i go to step on the gas pedel, i get no throttle...i've tried adjust the throttle cable to see if that what the problem but nothing?!?!? the only kinda of rpm accellateration i can get is if i mess w/ the distributor to advance or retard the timing? oh and i also tried unpluging the map sensor n tps on the throttle body while the car runs...but nothin happens? could it be that i have a bad tps or map sensor, because on the throttle body the tps broke, so i just bought a new one off someone and installed it....would that have anything to do w/ it?
Your guys help is really appreciated!!!! THANKS
Old Sep 25, 2005 | 12:02 PM
SpoonEk253's Avatar
Default Re: B20vtec Swap, no throttle?!?!? HELP!!! (SpoonEk253)
Old Sep 26, 2005 | 08:25 AM
Andres-eh2's Avatar
Did you try to accelerate the car from the throttle body?
Its either a timing issue or the map and tps
Old Sep 26, 2005 | 11:37 AM
SpoonEk253's Avatar
Default Re: (Andres-eh2)
its not timing....i think its my tps...since its not set right. and its not sending signal to the ecu
ATrin
Dec 10, 2005 01:25 PM
SpoonEk253
Sep 26, 2005 12:03 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
coupe_hybrid
Aug 27, 2004 09:39 AM
