Legend brakes on CRX Sir VTEC??
Is it possible with standard sir nuckles?
I have a 23T caliper bracket lying around here
so my cuestion is: does the 2-piston legend caliper fit this bracket?? and do i have to modify much?
/ Andreas
Modified by ADDE-VT at 4:11 AM 9/28/2005
Modified by ADDE-VT at 4:35 AM 9/28/2005
so my cuestion is: does the 2-piston legend caliper fit this bracket?? and do i have to modify much?/ Andreas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADDE-VT »</TD></TR><TR><TD CLASS="quote">So if Legend caliper bracket fits ITR knuckles....it will also fit CRX SiR knuckles???
/Andreas</TD></TR></TABLE>
The bolt spacing is the same. Yes!
i have nsx calipers with redrilled rotors on my 91 hatch...have to grind down the bracket to fit...use 28t brackets...ill try to find pics
ok pics are at http://www.tamparacing.com search for username r91si...there is a post i made about custom brake pics (title of the post)
hmm just FYI, nsx calipers have smaller pistons than the 95 GS legend calipers.
i just say this because i thought someone said they were the same, without the embossed "NSX" letters.
the legend pistons are actually bigger.
40/36mm NSX
42/38mm Legend
40/36mm NSX
42/38mm Legend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">hmmm are they aluminum? or just generally slightly lighter due to size?
Modified by Tyson at 11:30 PM 9/26/2005</TD></TR></TABLE>
Because they are alum.....and yes, they will fit EX knuckles.
Does anybody know if i can build my brakes with this parts? will it work?
Honda Legend 2-piston Caliper
Honda Odyssey/CRV 23T bracket
Rover ZS 180 282mm 25mm thick and 4*100
of course aim going to run 15" or 16" wheels....
Modified by ADDE-VT at 4:10 AM 9/28/2005
no you need 28t bracket and 28 mm rotor...i ran into this problem myself...the legend/nsx caliper is wider than a caliper designed for a 23t bracket...you will risk popping the caliper pistons out of the caliper when the pads start to wear if you use a 23 rotor...and no a 28mm rotor does not fit into a 23t bracket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">actually i asked my nsx expert, theyre not aluminum.</TD></TR></TABLE>
So what are they? They're like 1/2 the weight of a comparable sized Legend caliper.
Devil CRX
Oct 8, 2009 09:33 AM
ProfessorCRX
Sep 28, 2003 07:43 PM
