weird transmission noise
Old Sep 24, 2005 | 11:17 PM
super_nguyen's Avatar
Default weird transmission noise
everytime i start my car and begin to drive, (doesn't matter if reverse or first/second gear), around 1500 rpm's there is a loud grinding noise. i dunno what the sound could be, its odd because it only happens when i turn on my car and drive, never when im at a stop light. it sounds worse when i the car is cold, i've changed the transmission fluid (OEM honda MTF) but this failed to fix the sound. has anyone had this problem before?
Old Sep 25, 2005 | 09:24 AM
mmuller's Avatar
Mad Scientist
Default Re: weird transmission noise (super_nguyen)
its only at around 1500 rpms; or does it start at 1500 rpms?
im assuming its rpms related and not speed right?
Old Sep 25, 2005 | 04:09 PM
Default Re: weird transmission noise (mmuller)
yah its rpm related, only happens when i turn on the car, not when im sitting at a red light. the grind only lasts for like a second at 15-1700 rpm, i tried every different way of starting from a stop (even tried 3rd gear :S) nothing worked. any other suggestions
Old Sep 25, 2005 | 05:34 PM
BigMoose's Avatar
How many miles on the transmission?
Old Sep 25, 2005 | 07:34 PM
Default Re: weird transmission noise (BigMoose)
i live in canada but i have 125k which is roughly 78000 miles average for a 1999 car.
Old Sep 25, 2005 | 09:19 PM
rocketfuelcerx's Avatar
Does the grinding stop when the clutch is engaged?
Old Sep 25, 2005 | 09:52 PM
Default Re: weird transmission noise (rocketfuelcerx)
no it only happens when i start to move my car after its been turned on. it makes the sound whether or not my foot is on the clutch as long as its in a gear.
Old Sep 26, 2005 | 07:36 PM
flywheel???? damn i don't know...good luck though...bump
Old Sep 26, 2005 | 08:04 PM
redspiritguy's Avatar
my friends crx did the same thing, it was a internal trans problem. Some of the syncros or something was worn.
Dm914
Transmission & Drivetrain
Sep 9, 2015 03:29 AM
ihonda
14
Jun 21, 2012 07:31 AM
rivoe302er
Feb 19, 2007 05:43 AM
mntdewred
Jul 14, 2004 11:55 AM
ID_ten_T
May 20, 2004 07:49 PM
